Muffled audio issue since Fedora 44 upgrade
Which Linux distro are you using? Fedora
Which release version? 44
Which kernel are you using? 6.19.14-300.fc44.x86_64
Which BIOS version are you using? 3.18
Which Framework Laptop 13 model are you using? AMD Ryzen™ 7040 Series
Anyone experiencing muffled audio after upgrading to Fedora 44? I just upgrade over the weekend from Fedora 43 and my audio sounds low and muffled. It is also apparently affecting the built-in mic as my co-workers reported difficulty making out what I was saying in Teams meetings.
And right on point, as soon as I post on a forum looking for help I figured out the issue. Looks like the upgrade unset the audio profile on the audio device. Setting it back to Analog Stereo Duplex fixed the issue.
I have the same issue with the microphone but the sound config looks ok.
I rollbacked to Fedora 43 and the microphone works fine.
What could I do to fix the microphone issue on Fedora 44?
I get different results with `arecord -l`
On Fedora 43:
**** List of CAPTURE Hardware Devices ****
card 2: Generic_1 [HD-Audio Generic], device 0: ALC285 Analog [ALC285 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 2: Generic_1 [HD-Audio Generic], device 2: ALC285 Alt Analog [ALC285 Alt Analog]
  Subdevices: 2/2
  Subdevice #1: subdevice #1
card 3: acppdmmach [acp-pdm-mach], device 0: DMIC capture dmic-hifi-0 []
  Subdevices: 1/1
On Fedora 44:
  Subdevices: 1/1
  Subdevices: 2/2
The DMIC device is missing. But I can’t manage to get it back
Note: I’m on Bazzite
An issue has been opened on Bazzite.
