Multipurpose Expansion Bay Module
The card would have 4 external ports
● 1 for a battery under the laptop
● 1 Expansion Bay
● 2 Expansion Card slots (compatible with frameworks Expansion Card slots*)
It would also have some internal expansion NVME or 3.5" drives etc
it would probably be 2 or 3 times as thick as the FW 16 and as wide as it and 3 or 4 times the the with of a standard Expansion Card
●* the Expansion Card slots would support standard height width and depth plus any combination of
● double height
● 1.5 width on both sides (2.0 total)
● any depth in-between 1.0 and 2.0 (with the use of some spring mechanism)
