Hi,
I’ve had a few occurrences of this very annoying issue whereby my network adapter stops working after a few minutes of MS Teams call.
My call freezes, I check the tray bar and find out the WiFi icon has turned into the greyed out ethernet icon, as if the WiFi adapter itself went offline. Bluetooth adapter also becomes unavailable, as a result.
WiFi scanning is not available at this point, and even a systemctl restart NetworManager doesn’t do anything, which makes me suspect the issue is at kernel/WiFi driver level.
Eventually I have to reboot to bring the adapter back to life.
Has anyone experienced this?
I’m attaching the output of journalctl -k for the last occurrence. System info:
Operating System: openSUSE Tumbleweed 20250405
KDE Plasma Version: 6.3.4
KDE Frameworks Version: 6.12.0
Qt Version: 6.8.2
Kernel Version: 6.14.0-1-default (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 7840U w/ Radeon 780M Graphics
Memory: 30.7 GiB of RAM
Graphics Processor: AMD Radeon 780M
Manufacturer: Framework
Product Name: Laptop 13 (AMD Ryzen 7040Series)
System Version: A7
❯ lspci | grep Network
01:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
Thanks
