Hey all. Been waiting on response from support (X67DMW8R) for a while now and hadn’t yet found another with this exact problem on reddit, so sharing here to see if others might have resolved this driver or hardware issue. If not I’ll share what I find out here in case it helps gives any clarity to others.
Video of unmodified Ubuntu install media:
Issue observed on machine (delivered 11/11 within return period):
Specifically, the computer produces vertex explosions and stretched geometric polygons across desktop UI elements, missing font glyphs inside Firefox, and flickering black polygonal strips (triangles, lines, rectangles) all 3d games.
Tested mostly on CachyOS (COSMIC, Gnome, KDE) but same exact phenomenon seen directly using installation media for Ubuntu 26.04 and Ubuntu 26.10 with no modification
GNOME shows it the most on the desktop, but it’s prevalent a little bit in COSMIC and KDE and in all desktops it’s equally visible in 3d games
Summary of Troubleshooting Completed:
System Memory Verified Healthy: The system completed 8 full passes of MemTest86+ with 0 errors.
Multiple distros, desktops, kernels: Tested on CachyOS (including
linux-cachyosand mainline kernels) as well as stock Ubuntu installation media for both current and latest LTS, reproducing identical artifacts on both. -
3D & Browser Workloads: Confirmed artifacts persist across native 3D games, hardware-accelerated Firefox (with
MOZ_ENABLE_WAYLAND=1enforced), and desktop compositor UI rendering.CachyOS, COSMIC desktop:
Mesa Driver Testing: Tested both stable
mesaandmesa-gitpackages, and tested disabling Intel Color Control Surface compression and resource barriers (INTEL_DEBUG=noccs,noccs-modifier,no-resource-barrierandINTEL_DEBUG=norbc). -
Display settings: Checked that HDR was not set and turned off variable refresh rate
Kernel Display Flags: Tested disabling Panel Self Refresh and Panel Replay (
xe.enable_psr=0 xe.enable_panel_replay=0). -
Firmware & Kernel Logs: Updated to BIOS 03.04, verified
dmesglogs zero kernelxe/DRM driver faults or GuC firmware errors.
Some things seem to help a little bit, but it also could be just concidence, but nothing has solved it yet. Is the Xe3 graphics stack just totally borked for everyone on this setup, or is this maybe a hardware thing?
