Yubico is a hardware key for your passwords.
I would like to make a framework expansion card with a Yubikey, or better yet NFC expansion card.
Anybody else interested?
honestly, meh.
too single purpose. would rather a usb c or usb a card, and just putting an appropriate yubikey nano into it.
I think it would kind of defeat the purpose of a security key if it’s always attached to your computer.
I do swear by my Yubikey’s though. It may be cool if perhaps instead of a Yubico specific expansion card if perhaps an NFC reader expansion was added. Then you could authenticate with the NFC Yubikey’s by just tapping near the expansion.
or a replacement keyboard frame / panel with integrated NFC
Honestly you could probably make a simple plastic holder for the YubiKey 5C, it’s pretty small. if your threat modeling doesn’t include physical access
+1 for the NFC expansion card idea.
Could also repurpose the snack drawer as a yubikey holder
I like the idea of the NFC concept too; it was a tangential idea I had.
I renamed the topic to continue the NFC discussion
This might interest you all then ![]()
