It is related, I tested multiple times, after the disconnect it shows that error in the log.
Yep, it will be announce here. Nix team has already put this together - I am crafting my asks now to send them. Working directly with them.
Now we need to fill in the blanks with help from the community. This entry is for 11th gen, but we need it for all selections here.
https://wiki.nixos.org/wiki/Hardware/Framework/Laptop_13
We have two spaces, best to start here and let them know you want to join up and help with contributions here. They have set up a dedicated Matrix chat, but best start here and request directions on what works best for their team.
Are you sure that isnât just this upstream issue?
Yes, Iâm sure since it works with other Linux computers (my momâs computer thatâs running Arch currently)
Hi! I am seeing similar - did you find a solution?
Not sure if this solves it, but they did just merge Framework 16 support into the hardware repo here: Reposted added framework 16 by jkoking ¡ Pull Request #915 ¡ NixOS/nixos-hardware ¡ GitHub
I see it includes a tweak for Fix TRRS headphones missing a mic which might be related?
For your information: I found the following wiki pages about Framework Laptop.
I am having an issue where sometimes when I resume from hibernation, the wifi drivers are not loaded. I have to do sudo modprobe -r mt7921e && sleep 10 && sudo modprobe mt7921e to get wifi working again.
I am on an AMD framework running 23.11 with the latest kernel, using the nixos-hardware repo. My disk has luks encryping an LVM that has a root and swap volumns.
Not really sure where to start troubleshooting, but am open to suggestions.
First of all, what are the symptoms? Anything in dmesg? Do you see the physical interface e.g. in ip l? Also what do you mean by âdriversâ? You are saing that you have to do modrprobe -r, so sounds like the module gets loaded?
Is it worth making a dedicated subreddit related to framework and nixos called something like r/framework_nixos?
I personally donât want to make it as I dont want to mod⌠but I think the reddit format would be better suited to sharing configs / discussions over a forum basedâŚwhere most of the discussion is in a few threads what do you guys think?
Here is my current NixOS config:
My config is flake based, has the following:
On nixos-unstable (shifted from nixos 23.11)
Wayland
Plasma 6
Home-Manager with Plasma-manager
Looking to fix or add the following to my config:
- Speaker audio was louder in my initial nixos config.
Its quieter now be default. Not sure how to fix? - Charging via a powerbank does not charge at a decent rate. PowerBank is brand new: Anker 737. Replaced, same issue.
Charges at 88W when powered off, much lower when framework on (0-4w).
Error on bootup if powerbank is connected:
ucsi_acpi USBC000:00: unknown error 256
ucsi_acpi USBC000:00: con3: failed to register partner alt modes( -5)
dmesg, last boot log: Warp - Not sure how to set a wallpaper. Tried multiple ways and all have failed so far.
- Replace SSDM theme to sugar dark but hitting issues, raised an issue on vimjoyers github project related to video here:
sddm-theme sugar dark issues ¡ Issue #2 ¡ vimjoyer/theming-video ¡ GitHub - Need to move to a more module based NixOS config
Any suggestions or questions around my config or solutions to my issues are welcome. ![]()
edit:
didnât realize I had to run:
fwupdmgr refresh
fwupdmgr get-updates
fwupdmgr update
I am now on bios 3.03. I get less dmesg spam but still get:
UCSI_GET_PDOS failed (-70)
Looking at the framework 13 threads, apparently this is a known framework issue where the kernal canât negotiate over usb properly and I donât see a fix? This is pretty bad in my opinion if I canât use a power bank.
Relevant post in thread:
Is that a typo, and you meant 3.05? If not, thatâs the one you should get onto.
EDIT: sorry, didnât realize you were speaking about FW16. Please ignore. These separate NixOS threads - this and the FW16 one - sure are confusingâŚ
Interesting opportunity for NixOS users!
Might be worth renaming the Thread to âFramework 13 NixOS (Linux) users self-helpâ.
I can rename it, if everyone is okay with it.
Not sure what the best approach would be. Historically, all things Framework/NixOS ended up in this thread, regardless of the Framework flavor, and despite the Intel vs AMD differences. Then, a dedicated FW16 thread was created, which, arguably, still had a fair bit of content that applies equally to all FW laptops, and that led me to erroneously assume that all FW16 owners were posting there.
I believe, the discussions in both threads - and especially those collected in this one - may benefit all NixOS users, as most of us, it seems, are still figuring out how to best do things on NixOS in general. Maybe, one day the threads could get merged. In the meantime, I am monitoring both.
It would be helpful, and sufficient, I think, if everyone stated at the top of a post which platform they are using, if thatâs relevant. But itâs probably not realistic to expect. So, on my end, Iâll just try to be more mindful of the need to figure out which system is talked about, instead of jumping to conclusions ![]()
I would also like to see Framework CPU Usage LED module. I used it and keylightd on an arch install.
Iâm still wrapping my head around nix. Only been on the train for a few months.
Hi my microphone is not working on 13 AMD.
running pamixer --default-source --get-volume-human prints 100%
pamixer --list-sources prints:
Sources:
54 "alsa_output.pci-0000_c1_00.6.analog-stereo.monitor" "Suspended" "Monitor of Family 17h/19h HD Audio Controller Analog Stereo"
55 "alsa_input.pci-0000_c1_00.6.analog-stereo" "Suspended" "Family 17h/19h HD Audio Controller Analog Stereo"
144 "alsa_output.pci-0000_c1_00.1.hdmi-stereo.monitor" "Suspended" "Monitor of Rembrandt Radeon High Definition Audio Controller Digital Stereo (HDMI)"
idk what âSuspendedâ would mean in that output. And no the microphone hardware switch is not turned off.
my sound config:
sound.enable = true;
hardware.pulseaudio.enable = false;
security.rtkit.enable = true;
services.pipewire = {
enable = true;
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
How have you guys setup for microphone sound to work?
edit: oh and yea so ive tested it in both signal and obs and the only output i get is kinda like white noise.
Sorry for the late reply, but have you tried adjusting the profile for the internal sound device to Analog Stereo Duplex? I use pulsemixer for this: nix shell nixpkgs#pulsemixer --command pulsemixer.
Then hit F3 to go to the cards, press down to get to the Family 17h/19h HD Audio Controller, press Enter, then select Analog Stereo Duplex on the left popout menu. Then hit F2 to go to Input devices, press Down to select the Family 17h/19h HD Audio Controller Analog Stereo device, make sure it is unmuted (press M to toggle mute) and the volume is set to about 30 (a good level in my experience, yours may vary â you can press 3 to set it to 30).
Let me know if that helps at all! Also you definitely donât have anything plugged into the headphone jack, right?
https://wiki.nixos.org/wiki/PipeWire
sound.enable is only for ALSA based configs.
Note I created the following 2 pages redirecting to the âHardware/Framework/Laptop_13â. This is beneficial when the pages are used as a portal page for the Framework or Framework Laptop. I added the link to Wikipediaâs Framework Computer - External Links.
- https://wiki.nixos.org/wiki/Hardware/Framework
- https://wiki.nixos.org/wiki/Hardware/Framework/Laptop
#REDIRECT [[Hardware/Framework/Laptop_13]]
This mechanism is used in Arch Linux Wikiâs Framework Laptop page.
I have an interesting issue on my new Framework 13 AMD that I havenât seen here or in searches elsewhere.
On boot up, the screen goes blank and sits there (I let it sit for an hour before rebooting). It happens with both 23.11 usb and the just released today 24.05 usb.
I figured out a work around is to select nomodeset. This obviously cripples the graphics.
I was then able to install NixOS 24.05.
After reboot, the same thing happens after a brief screen showing âloading amdgpuâ, before I even get to the prompt to enter luks password. Had to add nomodeset to boot.kernelparams to get it to boot.
I added nixos-hardwareâs /framework/13-inch/7040-amd, but same thing is happening.
PS: I have updated the firmware to 3.5.
