Hi,
What is the logic for “no bootable hard drive detection” by UEFI?
The issue: I screwed up creating an UKI kernel image, which was missing most things, and when trying to boot the machine, it failed, rebooted itself into the “no bootable drive” QR code screen, and refused to see systemd-boot EFI executable until hard power off.
I now fixed my UKI generation, but this feels weird.
note : it might also be linked systemd-boot which apparently has no timeout.
Which Linux distro are you using? Gentoo (probably irrelevant)
Which kernel are you using? 6.16.3 (Probably irrelevant)
Which BIOS version are you using? 3.04
Which Framework Laptop 13 model are you using? AMD Ryzen™ AI 300
