Fedora
Which release version?
42
Which kernel are you using?
Linux 6.14.9-300.fc42.x86_64
03.08
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™) 12th Gen Intel® Core™
I cannot get any window to display (beyond splash screen, at least for Roblox studio) for any program running in Wine. In Fedora Workstation (GNOME), I can see the windows are supposed to be open, as GNOME overview shows the icon, but there is nothing where the window itself should be.
I first noticed this with Vinegar (Roblox Studio wrapper) but replicated it on Bottles with the Wine explorer in a new soda 9 and sys-wine 10 container.
Edit: Screenshot with wineglass
