Which Linux distro are you using? Arch linux
Which release version?
Which kernel are you using? 6.18
Which BIOS version are you using? 4.03
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040 Series + Nvidia
I expressed some hesitancy to grab an Nvidia module because the last time I had one it was nothing but issue with Wayland.
However, the general consensus was “it’s not that bad” or “its gotten a lot better”. I’m almost a week into this graphic module and all I can say is: WOW it has not gotten any better at all… if anything its worse"
I have been having nothing but issues.
Out the gate I couldn’t log into plasma. I would just get a black screen after logging in. Had to fix that by adding a bunch of modules the wiki doesnt mention.
Now, Only Office doesn’t load video anymore when running a Power Point file (it just crashes)
Power draw is double what I was getting when using the AMD module. So battery life is about 2 hours.
External monitors go in and out randomly.
Today I upgraded to Plasma 6.6, now I’m getting graphical glitches everywhere.
Honestly its bad. I’ve spent numerous attempts to fix the problem (tried different hooks, modules, drivers) and this is just across the board a mess.
Unfortunately I think I’m going to have to return this module, these problems are just too much. Unless of course I’m missing anything major.
Moral of the story: NVIDIA is NOT wayland ready. Do not buy if you are going to be using wayland.
