I am using Arch Linux. Just the default version. No Manjaro or anything like that.
Which release version?
Which kernel are you using?
The one that installs when you do “pacstrap /mountpoint linux”
I don’t know, but I don’t think it’s the latest one. Probably the one that just got shipped out when I purchased the laptop.
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
I’m using the Framework Laptop 16 with the AMD Ryzen 7040 Expansion Bay.
With those answers out of the way, I can try to explain in some more detail. For some reason, starting today, I’ve been having really strange and interesting graphical glitches on Arch Linux running KDE Plasma. I’ll include photographs too, but the first time it happened, it was really bad. It was green in some areas, it was black in some areas and all that. Then, it just completely froze up and then it came back even worse. It had a white triangle in the top left part. It had gone black in some places again, and all that too. Even while typing this all out, it’s flickering and being buggy. I don’t know if it’s an issue with the graphics bay or an issue with the software, but I would like some help if possible. Thank you!
Photographs attached below for more visual clarity.
Thank you in advanced!
RedLintu16
