Hi everyone,
I recently got a framework DIY edition, with the plan to use the SSD from my previous laptop, which I thought should be compatible – it’s an NVMe, not SATA, one notch… but when I boot the machine the BIOS doesn’t see it, and booting off of a Fedora live USB stick works, but then the OS can’t see the drive either (so it doesn’t look like it’s just a firmware thing). The only related existing thread I was able to find was here:
…but it doesn’t seem like the author came up with a solution other than buying a new drive. Folks in that thread asked about the contents of the drive, and I double checked it is already formatted with a GPT partition table (but I don’t think it would matter for the live USB being able to see it anyway…)
This is the exact drive I’m trying to put in: Western Digital WD BLACK SN750 NVMe M.2 2280 1TB SSD - Newegg.com
Am I missing anything? From everything I’ve found this drive should be compatible, and it still works fine putting it back into the other machine…
