Which kernel are you using?
6.14.3-300.fc42.x86_64
30.3.03
AMD Ryzen™ AI 300 Series
Problem:
When changing Input Audio Devices all Input Audio Devices disappear. This happens with attached external Audio Devices, but can easily be reproduced with the built in Audio Devices simple by switching the Input Audio Device from Digital Microphone to Internal Stereo Microphone. After that no Output Device is there anymore and I need to reboot or restart pipewire to make them appear again.
Does your “Digital Microphone” work? Does your (analog) “Internal Stereo Microphone?” work? So far, I have trouble using the internal microphone (input audio) no matter which one I select, digital or analog.
Both microphones work now and the disappearing of the output device is gone since installing blufine-dx:42.20250615.1. Gnome Input Device is still not showing in the quick settings.
