Painting the chassis
TL;DR: Is there a varnish or other chemical treatment on the original chassis of the FW13 AMD 7040 Series that would prevent a layer of primer from sticking properly?
I know almost nothing about painting. I first thought about having the chassis powder-coated by an auto/industrial shop, but then I saw the price. I’m now looking into spray cans instead, and I could order a colour very similar to my Lavender bezel. Apparently the Lavender colour is #BDA7F0, and the closest Pantone matches are either “Pantone 2645 U” (“uncoated”) or “Pantone 264 C” (“coated”).
I don’t understand what “coated” and “uncoated” mean in this context. To me, a coating is a layer added to protect something, in this case the paint underneath.
I know I have to prepare the metal surfaces of the chassis (or do I? /g). My guess is to use 400-grit sandpaper, since 180 seems very aggressive for this task, then clean the surface with rubbing alcohol (or acetone?). After that: primer, paint, varnish, reassembly, and done.
I also want to remove the logo, fill the holes, and paint over the area.
Do you know if the metal parts have a coating that would prevent primer from sticking? Are there any visible flaws in the process I have in mind?
The metal parts of the chassis I believe are just straight metal but buffed to the finish you see and touch. If you want to experiment with how the finished results might work try doing it to some of the expansion cards first.
Just keep paint away from the parts that fit to something else. This goes for anything that is being painted. The tolerances are probably not forgiving enough to have extra layers of paint and still fit nicely.
Stay away from Acetone unless you really really need it. It will destroy plastic parts in a hurry. Denatured alcohol will be just fine. To keep things extra clean pickup some tack cloths to get little bits of dust that might be attracted to parts.
The color will have a slightly different look if a clear coat is put on after painting vs just leaving it with the paint. Getting this uniform is not as easy as it sounds.
Yeah, always keep acetone (or nail polish remover, with is often mostly acetone) away from plastic products you own. Acetone melts / dissolves ABS and polycarbonate. It will make an ugly mess.
The plastics types favored for disposable bottles happen to be immune to acetone.
Do you think I can apply primer just after degreasing the part with alcohol?
Thank you for suggesting to try at small scale with expansion cards. It did not cross my mind, so thank you.
I did not know plastic bottles were immune to acetone, thank you :slight_smile:
Primer is pretty good at adhering to most surfaces as long as it is not super polished. Worst case, you rub/wipe it off with alcohol and then hit it with some 400 grit paper. Even 800 grit would probably be ok too and it is a fair amount more gentle if deciding painting is for the birds and abort the project.
Would be great to see some pictures of the progress. It is always fun to see someone’s journey through a new project with pictures of success and failures. We all make them!
I’ll post pictures as the painting jobs move forward: I don’t think you want to know that a can of paint cost ~20 EUR :sweat_smile:
Specialty color quality paint in an aerosol can is expensive. Surprised it is only 20 euro honestly.
There was a German company that specialized in spray paint for artists I read about years ago that was high end stuff.
I also thought it would be more expensive but, at the same time 20€ is already quite expensive to me, especially for a not necessary expense.
I looked a bit more into automotive paint and prices over around 26-30€ for the not “pro-grade spray paint” (I mean what does “pro-grade” mean when it is in cans).
I don’t know what the ideal paint should be for. Like would it be better to use art supplies, automotive ones, industrial… idk
Anyway, I also need to find time to disassemble, paint, etc, etc… so not now.
I actually don’t know when I’ll find a week where I don’t *need* my computer (uni, yay)
Could be done in February, April or during the summer break ¯\_(ツ)_/¯
Next steps are:
  • Deciding on a colour (yes, I’ve already changed my mind :') )
  • Finding a good paint that doesn’t need coating
  • Finding a time window where I can have my computer in pieces
How I feel reading the text back: Me generation - Wikipedia
I think the automotive paints are more industrious because vehicles are always thought of to be out in the elements, wind, dirt, rain, snow, etc. Industrial coatings are typically more resilient to chemicals and some abrasion. Mostly not being cleaned hardly ever and being able to withstand a manufacturing or industrial environment for longevity. Hard to go wrong with any of them for this application.
