Afraid not. That would have made things easier. There is usb 2.0 intended for a touchscreen, as well as i2c, but they are both on the display connector.
github.com/FrameworkComputer/Framework-Laptop-13/tree/main/Mainboard#display-interface
First issue is finding a display then ? The ideal thing would be to end up with a kit on the future marketplacy (probably around 250/300 dollars to stay reasonable with pricing, perhaps with a basic and premium tier idk)
If you just need usb you could grab it from somewhere else like the fingerprint reader or the webcam or somewhere if that’s the issue.
I would rather keep the fingerprint reader if possible, it’s just so practical, but i get the point there will be space even from the internal usb c port
There are more available usb ports all over the main-board.
I’ve been pondering about the display, seems pretty hard to source the steam deck / rog ally / aya neo 2 panel
The lenovo legion y700 panel might be perfect (1600p, 120hz) but i can’t find it as a stand alone. Seems to be a 40pin connector (or 30). I’ll leave a couple of links of what i found
I am also looking at finding one of those thick battery pack from aya neo or gpd as it could be pretty nice (the framework battery might be too long to make a usable for factor)
Edit : seems to be ok, however it has to be stacked so it making a thick boy
Edit 2 : a very quick mockup say that yes, it’s completely possible to compete against the steam deck in term of the/ thickness, depending on other factors of course (done quickly in sketchup so not the most accurate, the rectangle sticking out is to represent the max thickness of the MB+fan)
Stacking the battery on top won’t make it as thick as you might think. The mainboard is pretty slim even compared to some other laptop boards I’ve seen, and battery is no thicker than 6mm/quarter inch, so combined it should be no more than 15mm thick. Then add extra for the display, controller PCB and associated parts.
I can confirm this with proof of concept I’ve been using with a battery powered system that takes up a footprint inside the Steam Deck’s. I’ll probably post my own thread about it as I begin to build my own case.
Also, you can go with the bare panels that have a HDMI controller included. This means you’d need to take up one of the USB ports for an HDMI expansion card but it works pretty well. Here’s such a display kit that should work:
Very nice displya indeed, kinda worried about fitting the display driver board however (idk anything about pcb and stuff, perhaps a third party can be used ?)
Also unrelated question, are you the same CCricer than on the SSFnetwork forum ? (if so then i am very interested in your current framework handheld concept ) ![]()
I am also wondering if the framework team could come help streamline the entire project at the end, apparently the phawx has talked with them about making an handheld
Quick fitting make it doable, we just need a display that is just directly plugged into the Framework mobo edp pins, and 2 custom (perhaps 3 with a micro controller) for the inputs)
@Spycke yeah, that’s me from SFF Network forums. I had put my project on hold for a while, but this thread helped flare up my interest again and I will make my own build log thread here once I have something more tangible and concrete. The EDP approach is possible, because the battery won’t cover up the port. But I’m sticking to what works more easily for me which is the HDMI cable with expansion card.
All I have right now is a loose stack of computer parts with a USB hub. No case or any frame built to hold the stuff together, just a proof of concept that you can fit necessary parts in handheld form factor.
If the Phawx can influence the FW team to make their own handheld that would be awesome as well! He has just about every major handheld PC, even a prototype of the cancelled Smach Z lol
Ah nice to see you here as well !
Yeah hopefully the framework team can have a bit of ressources on such a project, fitting works, they could probably get a nicer display than us , and make daughter boards for the controls. THat would be the ultimate form of an handheld for me : dockable, upgradable with great warranty support
Let’s see if we can sudo make one to appeal to them or a third party ? (in fusion it should be enough, as a proof of concept)
Exclusive Images: This is the Lenovo Legion Go Gaming Handheld
Seen here https://www.youtube.com/watch?v=uLnkUFLZwlU
I hope this kind of device is what Framework is looking towards releasing next, after the FW16.
You add to that the possibility of adding a keyboard and pad to create a 2 in 1 tablet/small laptop and you have a very versatile device that can appeal to different kind of people.
You want a reparable upgradable handheld, that is it. You don’t game or are not interested in handhelds, but want a x86 tablet, that is it. You want a small ultra portable laptop or 2 in 1, that is it.
Plus it opens up Framework to the controllers market, which is yearning for an easy to repair option. Most people will not know, but most controllers are discarded because one of the joysticks and, less often, one of the buttons starts to slightly malfunction, but the rest of the controller is fine. Having the option to easily substitute the malfunctioning part, would have a great appeal to gamers.
The Legion Go is out and the design of the controllers looks really good, very interesting.
I wish Framework released something different with a detachable keyboard.
The only issue with the tablet design is you need the screen to be at least 10" in size for minimal bezel (there is a 10.5" FW mini tablet project here that does exactly that). And for some that screen size might be already too big for a gaming handheld.
I find the ideal screen size to be 7" to 8" though that would add a lot of bezel to the left and right. It’s all due to the dimensions of the mainboard. It’s not a square-ish “half-size” form factor like many of the handheld PCBs are. Which is also why the FW battery in the tablet needs to be stacked on top in order for it to fit in the case.
Is that really a problem when your controls are placed left and right in a handheld? So you wouldn’t have empty bezel to the left and right.
I have found this modular gaming handheld that uses a Framework board, and it looks promising. But it does illustrate what I was trying to point out with having bigger bezels on the left and right.
You’d have to use a screen much larger than 7" to take up the extra room. Although that’s also a matter of taste.
If you want the controller right over the bezel area, that is possible. Then you just have to make the design choice that they’ll not be detachable because they have to be on the same area as the sides of the mainboard.
I saw that video too. Looks awesome.
As a reference, below is the thread on the forum.
I have more parts to test with and have begun to 3D print a custom case for my handheld design. It’s not a horizontal Steam Deck style case. Instead, it will be a mini laptop/clamshell format not unlike GPD Win Max 2 where game pad controls are added towards the back. I’ll eventually make my own thread for this project as I do more work and I can provide pictures.
I’ll throw my hat into the ring on this one. I’ve got a housing/design for something like this over here. I modeled this using the official mainboard and battery CAD, and printed it all out as a prototype, which all fit together really nicely, in a sub 300mm width package excluding any controller dimensions. I don’t think I could narrow or slim down the design any further, since going any thinner would probably result in really poor thermals, and reducing the width would either structurally compromise it or result in a loss of features like the WiFi module. I suppose you could reduce the height, but that would start causing issues with installing the display and how the front housing attaches to the rear housing. Some have mentioned that JoyCons are a poor choice, but without designing a custom PCB or using some kind of Arduino (both of which I have limited or no experience with), they’re really the best option I can think of currently.
Very interesting, i dig the gpd win a lot, but on the fence with upgradability, hopefully oculinkc an be added too ? The hardest thing is to source a good display ![]()
Though honestly i kinda want the new steam deck OLED panel now ![]()
I am personnally looking to build something using an oculink connector (desktop replacement handheld) , using a storage expansion card from framework and external storage on a dock + charging when docked
Nonetheless i am super happy to see to see a lot of handheld project using the framework mobo !
