Am I missing something? I just put it all together and the ONLY place to plug in power is directly to a. Empty expansion port! Is a USB -C card necessary or can I just plug in directly to the empty card port? Friday night and I want to boot this up so desperately!!
You can plug it into an empty port, but getting a USB-C module is obviously highly recommended.
The order pages of the laptop where you select the modules tells you that you probably should get at least one USB-C module.
