Power draw on manjaro suspend
Hi Folks,
I normally use Ubuntu but I recently started dual-booting manjaro sway.
I noticed the power draw on suspend is much higher in manjaro. When running powerstat I measure ~1 Watt on Ubuntu and ~4 Watts on Manjaro.
Both systems are set to deep sleep mode in /sys/power/mem_sleep, and suspend is triggering fine when I check the logs with journalctl.
Any ideas on what could be going on?
Ubuntu, Manjaro
Which release version?
Ubuntu 24.04, Manjaro latest (as of date)
Which kernel are you using?
Linux 6.5.0-1027-oem
03.05
13th Gen Intel® Core™
