Hi all. Hoping some folks can take a look and give me a sanity check / guidance on the below outputs.
Are any of these warnings actual issues or do any actions need to be taken by me or otherwise to fix something?
I handpicked these from journalctl --dmesg after most recent boot, however they are listed in the opposite order than which they occurred (
Linux 6.8.1-arch1-1
Wayland/Gnome 45.5
7840U
3.03b
Output:
ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615)
ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
cros_ec_lpcs cros_ec_lpcs.0: EC ID not detected
i2c_hid_acpi i2c-FRMW0005:00: device did not ack reset within 1000 ms
i2c_hid_acpi i2c-FRMW0004:00: device did not ack reset within 1000 ms
i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
i8042: Warning: Keylock active
ACPI: thermal: [Firmware Bug]: Invalid critical threshold (-274000)
AACPI: thermal: [Firmware Bug]: No valid trip points!
AACPI: thermal: [Firmware Bug]: Invalid critical threshold (-274000)
PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
PCI: not using ECAM ([mem 0xe0000000-0xefffffff] not reserved)
PCI: [Firmware Info]: ECAM [mem 0xe0000000-0xefffffff] not reserved in ACPI motherboard resources
pci 0000:00:00.2: can't derive routing for PCI INT A
pci 0000:00:00.2: PCI INT A: not connected
I have some minor issues to work out with my system but overall it is running very good. However, I do want to try to understand these better. I did google each and didn’t landvery far with them so here I am. Any help, guidance, or advice is much appreciated.
