Random thing in the box
I just got my framework 16 in the mail, there was a part in the box that’s not in the instructions (or I’m blind).
What is it.
Interposer for the empty expansion bay shell, I assume you have order both that and have the GPU installed currently
This is the interposer if you have the shell and without the dual SSD carrier. The Dual SSD carrier use the GPU interposer.
Make you wonder if they should just give you the dual SSD carrier. It’s .. not a expensive PCB, and they can stop carrying this weird thing.
