Got my Framework Laptop last Thursday and installed Fedora 35 (5.16.9-200.fc35.x86_64 kernel). Everything is working well… except for the Wifi card (AX210) which is connecting to my home WiFi network (on the latest generation eero AP’s with WiFi6 support).
The main issues are:
- It doesn’t reattach to the network after any sustained period (more than a hour) of suspend state (laptop closed)
- Randomly craps out, sometimes in short succession, sometimes it then runs fine for 8+ hours.
It’s somewhat similar to Fedora 34: Wifi card crashing randomly - #13 by Andrew_Marshall but that was Fedora 34 instead of 35. In both cases, turning WiFi off and on successfully re-attaches to the network and all is well again.
Here are the relevent kernel messages:
[84883.920623] iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
[85798.920967] iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
[86107.927391] iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
[88561.509854] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[88561.510770] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[88561.510773] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[88561.510777] iwlwifi 0000:00:14.3: Loaded firmware version: 67.8f59b80b.0 QuZ-a0-hr-b0-67.ucode
[88561.510781] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[88561.510785] iwlwifi 0000:00:14.3: 0x0000A210 | trm_hw_status0
[88561.510787] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[88561.510790] iwlwifi 0000:00:14.3: 0x004CB2DE | branchlink2
[88561.510792] iwlwifi 0000:00:14.3: 0x004C1A5A | interruptlink1
[88561.510795] iwlwifi 0000:00:14.3: 0x004C1A5A | interruptlink2
[88561.510797] iwlwifi 0000:00:14.3: 0x0000B2C8 | data1
[88561.510799] iwlwifi 0000:00:14.3: 0x00001000 | data2
[88561.510801] iwlwifi 0000:00:14.3: 0x00000000 | data3
[88561.510803] iwlwifi 0000:00:14.3: 0xE0002D36 | beacon time
[88561.510806] iwlwifi 0000:00:14.3: 0x0E723725 | tsf low
[88561.510808] iwlwifi 0000:00:14.3: 0x000002BD | tsf hi
[88561.510810] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[88561.510812] iwlwifi 0000:00:14.3: 0x000590CA | time gp2
[88561.510815] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[88561.510817] iwlwifi 0000:00:14.3: 0x00000043 | uCode version major
[88561.510819] iwlwifi 0000:00:14.3: 0x8F59B80B | uCode version minor
[88561.510822] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[88561.510824] iwlwifi 0000:00:14.3: 0x00C89004 | board version
[88561.510826] iwlwifi 0000:00:14.3: 0x80BBFC03 | hcmd
[88561.510828] iwlwifi 0000:00:14.3: 0x24020000 | isr0
[88561.510830] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[88561.510833] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[88561.510835] iwlwifi 0000:00:14.3: 0x00C36C0C | isr3
[88561.510837] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[88561.510839] iwlwifi 0000:00:14.3: 0x04AA001C | last cmd Id
[88561.510841] iwlwifi 0000:00:14.3: 0x0000B2C8 | wait_event
[88561.510843] iwlwifi 0000:00:14.3: 0x00000080 | l2p_control
[88561.510846] iwlwifi 0000:00:14.3: 0x00010034 | l2p_duration
[88561.510848] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[88561.510850] iwlwifi 0000:00:14.3: 0x00000080 | l2p_addr_match
[88561.510852] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[88561.510854] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[88561.510856] iwlwifi 0000:00:14.3: 0x00004030 | flow_handler
[88561.511319] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[88561.511321] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[88561.511324] iwlwifi 0000:00:14.3: 0x20003463 | ADVANCED_SYSASSERT
[88561.511327] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[88561.511330] iwlwifi 0000:00:14.3: 0x80455E52 | umac branchlink2
[88561.511332] iwlwifi 0000:00:14.3: 0xC00811A4 | umac interruptlink1
[88561.511334] iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
[88561.511336] iwlwifi 0000:00:14.3: 0x0E723718 | umac data1
[88561.511338] iwlwifi 0000:00:14.3: 0x000590BB | umac data2
[88561.511340] iwlwifi 0000:00:14.3: 0x0F98C813 | umac data3
[88561.511343] iwlwifi 0000:00:14.3: 0x00000043 | umac major
[88561.511345] iwlwifi 0000:00:14.3: 0x8F59B80B | umac minor
[88561.511347] iwlwifi 0000:00:14.3: 0x000590C4 | frame pointer
[88561.511349] iwlwifi 0000:00:14.3: 0xC0885E00 | stack pointer
[88561.511351] iwlwifi 0000:00:14.3: 0x00B7010D | last host cmd
[88561.511353] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[88561.511514] iwlwifi 0000:00:14.3: IML/ROM dump:
[88561.511516] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state
[88561.511602] iwlwifi 0000:00:14.3: 0x00005DDF | IML/ROM data1
[88561.511690] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[88561.511707] iwlwifi 0000:00:14.3: Fseq Registers:
[88561.511745] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[88561.511778] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
[88561.511811] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[88561.511844] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[88561.511881] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[88561.511915] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[88561.511956] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[88561.511996] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[88561.512033] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[88561.512072] iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
[88561.512112] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[88561.512156] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Firmware version:
[ 18.164769] iwlwifi 0000:00:14.3: loaded firmware version 67.8f59b80b.0 QuZ-a0-hr-b0-67.ucode op_mode iwlmvm
Any ideas on any fixes? Thanks in advance.
