Over the past few days my WiFi has suddenly stopped working on my 12th Gen Framework running Gnome on Fedora 37, with the only remedy being an operating system reboot.
The UI icon for wifi in the top right goes hollow, and the “Visible Networks” list becomes empty. If I restart NetworkManager, the UI behaves as if my laptop has no WiFi adapter as the option for WiFi disappears from Gnome Settings.
What I’ve tried
Aside from rebooting (which works), this WiFi failure problem continues to occur after trying the following:
- An Intel WiFi fixer script from GitHub. This restarted
NetworkManagerwhich then caused all WiFi options to disappear from the UI as described previously. - Fully updating my system.
- Removing the
i915potential hard freeze fix (‘options i915 enable_psr=0’ in/etc/modprobe.d/i915.conf).
Environment
System information: inxi -bz
System:
Kernel: 6.1.18-200.fc37.x86_64 arch: x86_64 bits: 64 Desktop: GNOME v: 43.3
Distro: Fedora release 37 (Thirty Seven)
Machine:
Type: Laptop System: Framework product: Laptop (12th Gen Intel Core) v: A6
serial: <superuser required>
Mobo: Framework model: FRANMACP06 v: A6 serial: <superuser required>
UEFI: INSYDE v: 03.05 date: 08/23/2022
Battery:
ID-1: BAT1 charge: 31.1 Wh (60.2%) condition: 51.7/55.0 Wh (93.9%)
volts: 15.8 min: 15.4
CPU:
Info: 12-core (4-mt/8-st) 12th Gen Intel Core i7-1260P [MST AMCP]
speed (MHz): avg: 1957 min/max: 400/4700:3400
Graphics:
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
Device-2: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
driver: amdgpu v: kernel
Display: wayland server: X.Org v: 22.1.8 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: amdgpu,modesetting
unloaded: fbdev,radeon,vesa dri: iris gpu: i915 resolution: 2256x1504~60Hz
API: OpenGL v: 4.6 Mesa 22.3.7 renderer: Mesa Intel Graphics (ADL GT2)
Network:
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
Drives:
Local Storage: total: 1.82 TiB used: 978.42 GiB (52.5%)
Info:
Processes: 514 Uptime: 1h 22m Memory: 31.05 GiB used: 8.16 GiB (26.3%)
Shell: Zsh inxi: 3.3.25
Kernel args: sudo grubby --info=0 | grep args
Note: My kernel arguments haven’t been changed recently. WiFi had been stable for weeks with these args:
args="ro rootflags=subvol=root rd.luks.uuid=luks-38101d4c-c21e-49f4-9320-138a055fe380 rhgb quiet module_blacklist=hid_sensor_hub nvme.noacpi=1"
module_blacklist=hid_sensor_hub: Disable ambient light sensor so that keyboard brightness buttons functionnvme.noacpi=1: Improve suspend power usage
iwlwifi random failure during usage on kernel 6.1.15
This occurred whilst I was streaming a YouTube video.
$ journalctl --since '2023-03-15 10:16' --until '2023-03-15 10:16:45' | grep -Ev 'syncthing|Proton Mail|etesync-dav'
10:16:17 hostname kernel: pci_bus 0000:7f: Allocating resources
10:16:17 hostname kernel: pci_bus 0000:82: Allocating resources
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: Error sending STATISTICS_CMD: time out after 2000ms.
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: Current CMD queue read_ptr 6046 write_ptr 6047
10:16:22 hostname kernel: ------------[ cut here ]------------
10:16:22 hostname kernel: Timeout waiting for hardware access (CSR_GP_CNTRL 0xffffffff)
10:16:22 hostname kernel: WARNING: CPU: 11 PID: 1570 at drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2128 __iwl_trans_pcie_grab_nic_access+0x1ef/0x220 [iwlwifi]
10:16:22 hostname kernel: Modules linked in: amdgpu iommu_v2 gpu_sched drm_ttm_helper xt_CHECKSUM xt_MASQUERADE xt_conntrack bridge stp llc tls tun uinput rfcomm snd_seq_dummy snd_hrtimer dummy nfnetlink_queue nf_conntrack_netlink ip6t_REJECT nf_reject_ipv6 nft_chain_nat xt_nat nf_nat ipt_REJECT nf_reject_ipv4 xt_NFQUEUE xt_mark xt_connmark nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nft_compat nf_tables nfnetlink qrtr bnep sunrpc binfmt_misc vfat fat snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof snd_hda_codec_hdmi snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp snd_hda_codec_idt coretemp snd_soc_core snd_hda_codec_generic ledtrig_audio libarc4 snd_compress kvm_intel ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec kvm
10:16:22 hostname kernel: cros_ec_chardev iwlwifi cros_ec_sysfs snd_hda_core cros_usbpd_charger cros_usbpd_logger cros_usbpd_notify snd_hwdep btusb snd_seq btrtl iTCO_wdt btbcm btintel cros_ec_dev mei_hdcp mei_pxp mei_wdt snd_seq_device irqbypass intel_pmc_bxt btmtk cros_ec_lpcs pmt_telemetry cfg80211 iTCO_vendor_support intel_rapl_msr pmt_class cros_ec snd_pcm rapl bluetooth processor_thermal_device_pci intel_cstate processor_thermal_device snd_timer processor_thermal_rfim intel_uncore wmi_bmof pcspkr processor_thermal_mbox snd mei_me i2c_i801 processor_thermal_rapl mei joydev thunderbolt rfkill soundcore i2c_smbus idma64 intel_vsec igen6_edac intel_rapl_common int3403_thermal int3400_thermal int340x_thermal_zone acpi_thermal_rel acpi_pad loop zram dm_crypt i915 ttm nvme drm_buddy nvme_core drm_display_helper crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni hid_multitouch ucsi_acpi polyval_generic typec_ucsi ghash_clmulni_intel sha512_ssse3 serio_raw cec typec nvme_common i2c_hid_acpi
10:16:22 hostname kernel: video i2c_hid wmi pinctrl_tigerlake ip6_tables ip_tables fuse
10:16:22 hostname kernel: CPU: 11 PID: 1570 Comm: NetworkManager Not tainted 6.1.18-200.fc37.x86_64 #1
10:16:22 hostname kernel: Hardware name: Framework Laptop (12th Gen Intel Core)/FRANMACP06, BIOS 03.05 08/23/2022
10:16:22 hostname kernel: RIP: 0010:__iwl_trans_pcie_grab_nic_access+0x1ef/0x220 [iwlwifi]
10:16:22 hostname kernel: Code: 48 89 df e8 03 b3 fe ff 4c 89 f7 e8 3b 20 fb ed e9 e3 fe ff ff 89 c6 48 c7 c7 c8 3a e7 c0 c6 05 15 00 04 00 01 e8 01 cd 2a ed <0f> 0b e9 01 ff ff ff 48 8b 7b 40 48 c7 c2 30 3b e7 c0 31 f6 e8 48
10:16:22 hostname kernel: RSP: 0018:ffffa63fc152f580 EFLAGS: 00010286
10:16:22 hostname kernel: RAX: 000000000000003d RBX: ffff912e4ce08028 RCX: 0000000000000000
10:16:22 hostname kernel: RDX: 0000000000000203 RSI: ffffffffaf74aa5b RDI: 00000000ffffffff
10:16:22 hostname kernel: RBP: 00000000ffffffff R08: 0000000000000000 R09: ffffa63fc152f408
10:16:22 hostname kernel: R10: 0000000000000003 R11: ffffffffb0147448 R12: 0000000000000001
10:16:22 hostname kernel: R13: 0000000000000000 R14: ffff912e4ce0a974 R15: 0000000000000011
10:16:22 hostname kernel: FS: 00007f7537906500(0000) GS:ffff9135af8c0000(0000) knlGS:0000000000000000
10:16:22 hostname kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
10:16:22 hostname kernel: CR2: 00005626bb933af0 CR3: 000000012e3c6003 CR4: 0000000000770ee0
10:16:22 hostname kernel: PKRU: 55555554
10:16:22 hostname kernel: Call Trace:
10:16:22 hostname kernel: <TASK>
10:16:22 hostname kernel: iwl_trans_pcie_grab_nic_access+0x1b/0x40 [iwlwifi]
10:16:22 hostname kernel: iwl_force_nmi+0xdb/0x100 [iwlwifi]
10:16:22 hostname kernel: iwl_trans_sync_nmi_with_addr+0x147/0x170 [iwlwifi]
10:16:22 hostname kernel: iwl_trans_txq_send_hcmd+0x3b9/0x420 [iwlwifi]
10:16:22 hostname kernel: ? dequeue_task_stop+0x70/0x70
10:16:22 hostname kernel: iwl_trans_send_cmd+0x94/0xf0 [iwlwifi]
10:16:22 hostname kernel: iwl_mvm_send_cmd+0x1b/0x60 [iwlmvm]
10:16:22 hostname kernel: iwl_mvm_request_statistics+0x10b/0x190 [iwlmvm]
10:16:22 hostname kernel: ? iwl_mvm_tcm_iterator+0x30/0x30 [iwlmvm]
10:16:22 hostname kernel: iwl_mvm_mac_sta_statistics+0x1d9/0x350 [iwlmvm]
10:16:22 hostname kernel: sta_set_sinfo+0xbc/0xba0 [mac80211]
10:16:22 hostname kernel: ieee80211_dump_station+0x6b/0x90 [mac80211]
10:16:22 hostname kernel: nl80211_dump_station+0x121/0x250 [cfg80211]
10:16:22 hostname kernel: ? prepare_alloc_pages.constprop.0+0xa7/0x1a0
10:16:22 hostname kernel: netlink_dump+0x120/0x310
10:16:22 hostname kernel: __netlink_dump_start+0x1b6/0x2f0
10:16:22 hostname kernel: genl_family_rcv_msg_dumpit+0x8c/0x110
10:16:22 hostname kernel: ? genl_family_rcv_msg_doit+0x130/0x130
10:16:22 hostname kernel: ? nl80211_send_station+0xf20/0xf20 [cfg80211]
10:16:22 hostname kernel: ? genl_family_rcv_msg_dumpit+0x110/0x110
10:16:22 hostname kernel: genl_rcv_msg+0x182/0x240
10:16:22 hostname kernel: ? nl80211_dump_station+0x250/0x250 [cfg80211]
10:16:22 hostname kernel: ? genl_start+0x160/0x160
10:16:22 hostname kernel: netlink_rcv_skb+0x4e/0x100
10:16:22 hostname kernel: genl_rcv+0x24/0x40
10:16:22 hostname kernel: netlink_unicast+0x21b/0x360
10:16:22 hostname kernel: netlink_sendmsg+0x242/0x4a0
10:16:22 hostname kernel: sock_sendmsg+0x5c/0x70
10:16:22 hostname kernel: ____sys_sendmsg+0x277/0x2f0
10:16:22 hostname kernel: ___sys_sendmsg+0x9a/0xe0
10:16:22 hostname kernel: __sys_sendmsg+0x68/0xa0
10:16:22 hostname kernel: do_syscall_64+0x58/0x80
10:16:22 hostname kernel: ? syscall_exit_to_user_mode+0x17/0x40
10:16:22 hostname kernel: ? do_syscall_64+0x67/0x80
10:16:22 hostname kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd
10:16:22 hostname kernel: RIP: 0033:0x7f7538956f3d
10:16:22 hostname kernel: Code: 28 89 54 24 1c 48 89 74 24 10 89 7c 24 08 e8 9a 96 f7 ff 8b 54 24 1c 48 8b 74 24 10 41 89 c0 8b 7c 24 08 b8 2e 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 33 44 89 c7 48 89 44 24 08 e8 ee 96 f7 ff 48
10:16:22 hostname kernel: RSP: 002b:00007ffe82656c40 EFLAGS: 00000293 ORIG_RAX: 000000000000002e
10:16:22 hostname kernel: RAX: ffffffffffffffda RBX: 000056275f8a2680 RCX: 00007f7538956f3d
10:16:22 hostname kernel: RDX: 0000000000000000 RSI: 00007ffe82656c80 RDI: 000000000000000b
10:16:22 hostname kernel: RBP: 000056275f8a2680 R08: 0000000000000000 R09: 0000000000000000
10:16:22 hostname kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007ffe82656d10
10:16:22 hostname kernel: R13: 000056275f98d280 R14: 00007ffe82656f44 R15: 000056275f890dd0
10:16:22 hostname kernel: </TASK>
10:16:22 hostname kernel: ---[ end trace 0000000000000000 ]---
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: iwlwifi transaction failed, dumping registers
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: iwlwifi device config registers:
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000000: 27258086 00100000 0280001a 00000000 00000004 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000020: 00000000 00000000 00000000 00248086 00000000 000000c8 00000000 00000100
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000040: 00028010 10008ec0 001b0c10 0045e812 10120000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000060: 00000000 00080812 00000005 00000006 00000002 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000080: 000f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000100: 14c10001 00100000 00000000 00462031 00003141 00002000 00000014 40000001
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000120: 0000000f 7a200460 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000140: 14c00000 ff000000 000000ff 15410018 00000000 0001001e 00481e1f 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: iwlwifi device memory mapped registers:
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: iwlwifi device AER capability structure:
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000000: 14c10001 00100000 00000000 00462031 00003141 00002000 00000014 40000001
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: 00000020: 0000000f 7a200460 00000000
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: iwlwifi parent port (0000:00:1d.0) config registers:
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000000: 51b08086 00100407 06040001 00810010 00000000 00000000 00a6a600 200000f0
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000020: 7a207a20 0001fff1 00000000 00000000 00000000 00000040 00000000 000201ff
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000040: 01428010 00008001 00110000 09724c13 70120042 0044b200 01400000 00000008
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000060: 00000000 00080837 00000000 0000000e 00000002 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000080: 00019005 fee00338 00000000 00000000 0000a00d 0002f111 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 000000a0: c8030001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 000000c0: 00000000 00000000 00000000 00000000 06008001 40011842 099e0008 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 000000e0: 00f3f700 8a778a77 00138006 00000000 00000150 50000300 01010fb5 01000004
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000100: 22010001 00000000 00000000 00060011 00000081 00002000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000140: 00000000 00000000 00000000 00000000 2001001f 00000406 00000003 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000200: a301001e 00b0283f 4058281f
10:16:22 hostname kernel: iwlwifi 0000:a6:00.0: iwlwifi root port (0000:00:1d.0) AER cap structure:
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000000: 22010001 00000000 00000000 00060011 00000081 00002000 00000000 00000000
10:16:22 hostname kernel: iwlwifi 0000:00:1d.0: 00000020: 00000000 00000000 00000000 00000000 00000000 00000000
10:16:22 hostname kernel: WARNING: CPU: 11 PID: 1570 at drivers/net/wireless/intel/iwlwifi/iwl-trans.h:1414 iwl_fwrt_dump_lmac_error_log+0x4ae/0x500 [iwlwifi]
10:16:22 hostname kernel: CPU: 11 PID: 1570 Comm: NetworkManager Tainted: G W 6.1.18-200.fc37.x86_64 #1
10:16:22 hostname kernel: RIP: 0010:iwl_fwrt_dump_lmac_error_log+0x4ae/0x500 [iwlwifi]
10:16:22 hostname kernel: Code: c4 a0 00 00 00 5b 5d 41 5c 41 5d 41 5e c3 cc cc cc cc 81 fd ff ff 3f 00 0f 87 05 fc ff ff 49 c7 c0 c5 08 e7 c0 e9 b0 fb ff ff <0f> 0b 49 8b 7c 24 40 48 c7 c2 b0 59 e7 c0 31 f6 e8 7d fe fd ff 49
10:16:22 hostname kernel: RSP: 0018:ffffa63fc152f4d0 EFLAGS: 00010286
10:16:22 hostname kernel: RAX: 00000000fffffff0 RBX: ffff912e4b00af50 RCX: 0000000000000000
10:16:22 hostname kernel: RDX: 0000000000000001 RSI: ffffffffaf7eb883 RDI: 00000000ffffffff
10:16:22 hostname kernel: RBP: 00000000004f1f00 R08: 0000000000000000 R09: 0000000033483483
10:16:22 hostname kernel: R10: ffffffffb0006110 R11: ffffa63fc03e8ff8 R12: ffff912e4ce08028
10:16:22 hostname kernel: R13: 0000000000000000 R14: ffffa63fc152f4d8 R15: 0000000000000000
10:16:22 hostname kernel: iwl_fwrt_dump_error_logs+0x24/0x1e0 [iwlwifi]
10:16:22 hostname kernel: iwl_mvm_nic_error+0xa3/0xd0 [iwlmvm]
10:16:22 hostname kernel: iwl_trans_sync_nmi_with_addr+0x75/0x170 [iwlwifi]
... redacted logs to stay within character limit ...
10:16:31 hostname avahi-daemon[1313]: Interface wlp166s0.IPv6 no longer relevant for mDNS.
10:16:31 hostname avahi-daemon[1313]: Leaving mDNS multicast group on interface wlp166s0.IPv6 with address fe80::c31c:1818:9f42:d3ab.
10:16:31 hostname avahi-daemon[1313]: Interface wlp166s0.IPv4 no longer relevant for mDNS.
10:16:31 hostname avahi-daemon[1313]: Leaving mDNS multicast group on interface wlp166s0.IPv4 with address 192.168.1.38.
10:16:31 hostname avahi-daemon[1313]: Withdrawing address record for fe80::c31c:1818:9f42:d3ab on wlp166s0.
10:16:31 hostname avahi-daemon[1313]: Withdrawing address record for 192.168.1.38 on wlp166s0.
10:16:31 hostname NetworkManager[1570]: <info> [1678875391.3383] device (wlp166s0): supplicant interface state: completed -> interface_disabled
10:16:31 hostname NetworkManager[1570]: <info> [1678875391.3384] device (p2p-dev-wlp166s0): supplicant management interface state: completed -> interface_disabled
10:16:32 hostname abrt-dump-journal-oops[1568]: abrt-dump-journal-oops: Found oopses: 22
10:16:32 hostname abrt-dump-journal-oops[1568]: abrt-dump-journal-oops: Creating problem directories
10:16:33 hostname abrt-server[17041]: Deleting problem directory oops-2023-03-15-10:16:32-1568-0 (dup of oops-2023-03-10-20:08:47-1554-0)
10:16:33 hostname abrt-notification[17050]: System encountered a non-fatal error in kvfree_call_rcu()
10:16:34 hostname abrt-server[17045]: Deleting problem directory oops-2023-03-15-10:16:32-1568-1 (dup of oops-2023-03-10-09:11:33-1518-1)
10:16:34 hostname abrt-notification[17059]: System encountered a non-fatal error in ieee80211_do_stop()
10:16:36 hostname abrt-server[17058]: Can't find a meaningful backtrace for hashing in '.'
10:16:36 hostname kernel: pci_bus 0000:7f: Allocating resources
10:16:36 hostname kernel: pci_bus 0000:82: Allocating resources
10:16:36 hostname abrt-server[17058]: Preserving oops '.' because DropNotReportableOopses is 'no'
10:16:36 hostname abrt-dump-journal-oops[1568]: Reported 22 kernel oopses to Abrt
10:16:36 hostname abrt-dump-journal-oops[1568]: abrt-dump-journal-oops: Sleeping for 289 seconds
10:16:37 hostname abrt-notification[17093]: System encountered a non-fatal error in ??()
10:16:38 hostname abrt-server[17070]: Can't find a meaningful backtrace for hashing in '.'
10:16:38 hostname abrt-server[17070]: Preserving oops '.' because DropNotReportableOopses is 'no'
10:16:39 hostname abrt-notification[17177]: System encountered a non-fatal error in ??()
10:16:40 hostname portmaster-start[1325]: 230315 10:16:40.356 nameserver:286 ▶ WARN 031 nameserver: failed to resolve detectportal.firefox.com.A: all 3 query-compliant resolvers failed, last error: read udp 10.24.0.3:39070->192.168.1.1:53: i/o timeout
10:16:40 hostname portmaster-start[1325]: 230315 10:16:40.356 nameserver:286 ▶ WARN 033 nameserver: failed to resolve detectportal.firefox.com.AAAA: all 3 query-compliant resolvers failed, last error: read udp 10.24.0.3:10709->192.168.1.1:53: i/o timeout
10:16:40 hostname abrt-server[17079]: Can't find a meaningful backtrace for hashing in '.'
10:16:40 hostname abrt-server[17079]: Preserving oops '.' because DropNotReportableOopses is 'no'
10:16:41 hostname abrt-notification[17195]: System encountered a non-fatal error in ??()
Please find the complete log sample here: https://haste.tchncs.de/gakoviwoxi
Additional information
I also have logs for another iwlwifi failure on 2023-03-14 which occurred as I woke the laptop from suspend.
Both times I have captured logs for this issue I have also had an eGPU connected via thundererbolt which itself has been having issues. There may be a possibility the eGPU is causing problems on my system resulting in iwlwifi failing. However, I have already been using my laptop plugged into this eGPU (for charging & further troubleshooting) for several months in the same room and had stable WiFi until just a few days ago.
Please advise.
