- Fedora 39
- FW 16 Ryzen 7 7840
- updated driver and went through update and all;
I am a relative newbie to linux environment so any dumbed down instruction through terminal would be appreciated if terminal is needed.
My laptop doesn’t seem to see any bluetooth hardware.
Might be relevant information:
USB A connected bluetooth device works fine.
Wifi works fine.
Once in a while after stand down mode, laptop seems to have issue responding to any keyboard input or mouse/trackpad input and after waiting 1-2 minutes, it starts working well (screen is on the entire time while waiting)
have the FW16, and I see Bluetooth here. Make sure you don’t have airplane mode active or bluetooth disabled.
Using KDE Neon here. So no idea what it looks like on Fedora.
when I look into terminal; under
$ inxi --bluetooth
No bluetooth data found
I didn’t see any bluetooth option enable/disable option on BIOS either…
What driver update was that referring to? Drivers are all in the kernel, you shouldn’t need anything “extra”.
On FW 13 AMD here but presumably same adapter? Also under Fedora 39, currently 6.8.4-200.fc39.x86_64 but was same under previous kernels too:
$ lsusb |grep -i mediatek
Bus 001 Device 004: ID 0e8d:e616 MediaTek Inc. Wireless_Device
Does lsusb show it on your machine too?
Might be worth re-seating the WiFi/BT adapter if you haven’t done so yet.
forgive me for probably the wrong word to use there for “driver” I meant whatever update that Fedora 39 prompted itself to go through? still getting my feet wet to the linux world from windows
As far as your question:
lsusb
Bus 001 Device 002: ID 32ac:0002 Framework HDMI Expansion Card
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 006: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 007: ID 32ac:0013 Framework Laptop 16 RGB Macropad
Bus 001 Device 010: ID 27c6:609c Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
Bus 001 Device 013: ID 32ac:0012 Framework Laptop 16 Keyboard Module - ANSI
Bus 002 Device 002: ID 05e3:0625 Genesys Logic, Inc. USB3.2 Hub
Bus 003 Device 002: ID 0bda:5634 Realtek Semiconductor Corp. Laptop Camera
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Above is what I get so no I don’t see it unless I’m blind…
weird… wireless works fine…
Update:
Thanks for the suggestion of re-seating.
That actually did fix it. Being PC builder helps now weirdly enough “laptop builder”??
