After upgrading to kernels 6.7.3 and 6.7.4, I could not boot my 12th-gen Intel laptop. Boot would freeze at “Loading Linux…” and by removing quiet boot, I found that there was a kernel panic.
I discovered by chance when trying to switch default kernels that running sudo grub2-mkconfig -o /boot/grub2/grub.cfg would allow me to boot into the affected kernels.
At least one other user experienced the same problem. Unfortunately, both cases are oddly specific, leaving several possible causes:
12th Gen Intel
Some configuration of Grub
Using LUKS
Intially or currently dual booted with Windows
Use TLP (though disabling it does not fix the issue)
I made this as a new thread because it does not solely affect 6.7.3 and is not resolved.
He is unable to mount the root filesystem (As stated in some of the last lines of your 2nd screenshot).
First, it tells you it can’t open the device (using the device mapper). And in the device mapper I see you use not only the device mapper redhat os loves to use, but also Luks (disk ncryption). In fact, 3 things to check:
Disk
device mapper mappings
Encryption.
I would simply boot from a recovery USB stick, and see if you can mount the encrypted partition yourself. But that gets complication pretty fast:
Identify the partitions with lsblk
rearrange the “partitions” using the device mapper
mount the partition using luks to mount it locally.
If that works, your initial image (for booting) is probably broken. if not , check the rest.
Sorry - but not time to write a walk through on this.
At this stage, Jorge’s advice is going to be the best path forward. I’m on 6.7.4-200.fc39.x86_64 on most of my Framework laptops and have not had issues with it. The fact that you need to sudo grub2-mkconfig -o /boot/grub2/grub.cfg tells me something went sideways.
Jorge’s advice is where I’d start at this stage. I don’t have time today to charge my 12th gen and repo this as I doubt I would be able to trigger the error.
Thanks to both you and @Jorg_Mertin. I am pretty busy right now, but I will get to testing at some point. Until then, I’ll just have to keep backing up.
