[RESPONDED] Framework 13th AMD with Raspberry Pi board, fails to connect/initiate device Ethernet-CDC, USB device disconnects intempestively
NixOS
Which release version?
24.05
Rolling release possible using unstable branch
Which kernel are you using?
6.10.3
3.05
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
AMD Ryzen 7040 Series, 7 7480U, 64GB, Expansion card USB-A
Logs :
[550675.670174] usb 1-2: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 6.01
[550675.670181] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[550675.670184] usb 1-2: Product: RNDIS/Ethernet Gadget
[550675.670187] usb 1-2: Manufacturer: Linux 6.1.21+ with 20980000.usb
[550675.732461] cdc_ether 1-2:1.0 usb0: register 'cdc_ether' at usb-0000:c1:00.3-2, CDC Ethernet Device, 0e:5c:ef:c1:c8:f2
[550675.746189] cdc_ether 1-2:1.0 enp193s0f3u2: renamed from usb0
[550675.775867] usb 1-2: USB disconnect, device number 26
[550675.776078] cdc_ether 1-2:1.0 enp193s0f3u2: unregister 'cdc_ether' usb-0000:c1:00.3-2, CDC Ethernet Device
[550676.016386] usb 1-2: new high-speed USB device number 27 using xhci_hcd
[550676.147301] usb 1-2: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 6.01
[550676.147310] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[550676.147314] usb 1-2: Product: RNDIS/Ethernet Gadget
[550676.147317] usb 1-2: Manufacturer: Linux 6.1.21+ with 20980000.usb
[550676.212469] cdc_ether 1-2:1.0 usb0: register 'cdc_ether' at usb-0000:c1:00.3-2, CDC Ethernet Device, 0e:5c:ef:c1:c8:f2
[550676.224132] cdc_ether 1-2:1.0 enp193s0f3u2: renamed from usb0
[550679.300017] usb 1-2: USB disconnect, device number 27
[550679.300171] cdc_ether 1-2:1.0 enp193s0f3u2: unregister 'cdc_ether' usb-0000:c1:00.3-2, CDC Ethernet Device
[550680.348339] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[550680.463308] usb 1-2: new high-speed USB device number 29 using xhci_hcd
[550680.800106] usb 1-2: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 6.01
[550680.800113] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[550680.800117] usb 1-2: Product: RNDIS/Ethernet Gadget
[550680.800119] usb 1-2: Manufacturer: Linux 6.1.21+ with 20980000.usb
[550680.852569] cdc_ether 1-2:1.0 usb0: register 'cdc_ether' at usb-0000:c1:00.3-2, CDC Ethernet Device, 0e:5c:ef:c1:c8:f2
[550680.869431] cdc_ether 1-2:1.0 enp193s0f3u2: renamed from usb0
Anyone else having the same issues with Raspberry Pi, I have tested an RPI Zero v1.3 and an RPI v1 as well as an RPI v3.
All those devices could not establish a connection to my Framework device via USB.
I’m not sure if it’s due to me being on KDE specifically or not hence why I would like feedback from other users ? There might be something wrong with my configuration.
Hi @AkechiShiro, Have you tried different USB Cables to the RPI?
