Hello! I’m having a weird issue with my Framework 13 AMD running Arch Linux. After leaving the system unused and unplugged for a week, USB and Bluetooth stopped working, but only in Arch Linux – Windows 11 is fine.
- Specifically, I’m trying to use a wireless Logitech keyboard and mouse, each with separate USB dongles; they are not connected via Bluetooth.
- The two dongles are plugged into my Dell monitor, which is connected via USB-C to my laptop.
- This configuration worked fine until I left the system unused and turned off for a week. It still works without issue in Windows 11. The same hardware works fine with my MacBook Pro M3.
- I am running the latest BIOS (3.05). The issue first appeared while running kernel 6.9.1, and has persisted since upgrading to kernel 6.9.5. The same problem occurs in kernel 6.6.34 LTS.
- I tried resetting the BIOS settings.
- I also tried using the “disconnect battery” option in the BIOS, then leaving the system off for 20 minutes.
- Based on other related reports, I also tried rebuilding my initrd without Bluetooth modules. This did not help.
- I tried using a cheap USB wireless mouse instead, which also didn’t work. I also tried without success to use the Logitech mouse and keyboard with a separate USB-C hub without connecting my monitor. Notably my laptop’s webcam also no longer works, suggesting something is wrong with the entire USB subsystem.
dmesg shows voluminous output related to Bluetooth and USB repeatedly resetting. While the system is running, the following messages are logged approximately every three seconds:
[ 885.538317] usb 1-1: USB disconnect, device number 8
[ 885.656405] usb 1-4: USB disconnect, device number 9
[ 885.657116] usb 1-5: USB disconnect, device number 10
[ 885.678149] Bluetooth: hci0: sending frame failed (-19)
[ 885.678166] Bluetooth: hci0: Failed to send wmt patch dwnld (-19)
[ 885.678213] Bluetooth: hci0: Failed to set up firmware (-19)
[ 885.678218] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 885.715560] usb 3-1: USB disconnect, device number 88
[ 886.894948] hub 1-0:1.0: USB hub found
[ 886.894979] hub 1-0:1.0: 5 ports detected
[ 886.899970] usb usb1: authorized to connect
[ 886.900266] hub 2-0:1.0: USB hub found
[ 886.900278] hub 2-0:1.0: 2 ports detected
[ 886.902100] usb usb2: authorized to connect
[ 886.961595] hub 3-0:1.0: USB hub found
[ 886.961628] hub 3-0:1.0: 1 port detected
[ 886.963287] usb usb3: authorized to connect
[ 886.963476] hub 4-0:1.0: USB hub found
[ 886.963496] hub 4-0:1.0: 1 port detected
[ 886.964434] usb usb4: authorized to connect
[ 886.978318] hub 5-0:1.0: USB hub found
[ 886.978398] hub 5-0:1.0: 1 port detected
[ 886.980133] usb usb5: authorized to connect
[ 886.980451] hub 6-0:1.0: USB hub found
[ 886.980493] hub 6-0:1.0: 1 port detected
[ 886.983226] usb usb6: authorized to connect
[ 886.995198] hub 7-0:1.0: USB hub found
[ 886.995247] hub 7-0:1.0: 1 port detected
[ 886.997039] usb usb7: authorized to connect
[ 886.997369] hub 8-0:1.0: USB hub found
[ 886.997410] hub 8-0:1.0: 1 port detected
[ 886.999739] usb usb8: authorized to connect
[ 887.044805] usb 1-1: new full-speed USB device number 11 using xhci_hcd
[ 887.111466] usb 3-1: new high-speed USB device number 89 using xhci_hcd
[ 887.222579] usb 1-1: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
[ 887.222590] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 887.222594] usb 1-1: Product: HDMI Expansion Card
[ 887.222597] usb 1-1: Manufacturer: Framework
[ 887.222601] usb 1-1: SerialNumber: 11AD1D00B21A3F111B0A0B00
[ 887.282581] usb 3-1: New USB device found, idVendor=0bda, idProduct=5634, bcdDevice= 0.21
[ 887.282591] usb 3-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 887.282596] usb 3-1: Product: Laptop Camera
[ 887.282599] usb 3-1: Manufacturer: Generic
[ 887.282602] usb 3-1: SerialNumber: 200901010001
[ 887.285749] hid-generic 0003:32AC:0002.01C7: hiddev96,hidraw1: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:c1:00.3-1/input1
[ 887.294352] usb 3-1: Found UVC 1.00 device Laptop Camera (0bda:5634)
[ 887.411450] usb 1-4: new full-speed USB device number 12 using xhci_hcd
[ 887.583529] usb 1-4: New USB device found, idVendor=27c6, idProduct=609c, bcdDevice= 1.00
[ 887.583535] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 887.583537] usb 1-4: Product: Goodix USB2.0 MISC
[ 887.583538] usb 1-4: Manufacturer: Goodix Technology Co., Ltd.
[ 887.583540] usb 1-4: SerialNumber: UIDC5FFF269_XXXX_MOC_B0
[ 887.714775] usb 1-5: new high-speed USB device number 13 using xhci_hcd
[ 887.858566] usb 1-5: New USB device found, idVendor=0e8d, idProduct=e616, bcdDevice= 1.00
[ 887.858576] usb 1-5: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[ 887.858581] usb 1-5: Product: Wireless_Device
[ 887.858584] usb 1-5: Manufacturer: MediaTek Inc.
[ 887.858587] usb 1-5: SerialNumber: 000000000
Mashing keys on my Logitech wireless keyboard while its dongle is active leads to these errors:
Jun 18 10:07:18 mango kernel: logitech-djreceiver 0003:046D:C52B.003E: logi_dj_probe: logi_dj_recv_switch_to_dj_mode returned error:-19
Jun 18 10:07:24 mango kernel: logitech-djreceiver 0003:046D:C52B.0047: can't resubmit intr, 0000:c3:00.3-1.3/input2, status -19
Does anyone have any idea how to fix this?
