System
========================== Kernel ===============================
Installed kernel: 6.6.7-200.fc39.x86_64
========================== Operating System =====================
OS: Fedora Linux 39 (Workstation Edition) x86_64
Host: Laptop (12th Gen Intel Core) A4
Kernel: 6.6.7-200.fc39.x86_64
Uptime: 2 hours, 27 mins
Packages: 7193 (rpm), 202 (brew), 45 (flatpak)
Shell: bash 5.2.21
Resolution: 2256x1504
DE: GNOME 45.2
WM: Mutter
WM Theme: Adwaita
Theme: NumixSolarizedDarkOrange [GTK2/3]
Icons: Solarized-FLAT-Orange [GTK2/3]
Terminal: vscode
CPU: 12th Gen Intel i5-1240P (16) @ 4.400GHz
GPU: Intel Alder Lake-P GT2 [Iris Xe Graphics]
Memory: 8191MiB / 31802MiB
Display Server: wayland
Systemd Version: systemd 254 (254.7-1.fc39)
~~~~~~~~~~~~~~~~~~~~~~~~~~~Machine~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Machine:
Type: Laptop System: Framework product: Laptop (12th Gen Intel Core) v: A4
serial: FRANDACPA42382002Q
Mobo: Framework model: FRANMACP04 v: A4 serial: FRANMACPA423620037
UEFI: INSYDE v: 03.06 date: 11/10/2022
~~~~~~~~~~~~~~~~~~~~~~~~~~~CPU~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
CPU:
Info: 12-core (4-mt/8-st) model: 12th Gen Intel Core i5-1240P bits: 64
type: MST AMCP cache: L2: 9 MiB
Speed (MHz): avg: 697 min/max: 400/4400:3300 cores: 1: 808 2: 848 3: 860
4: 900 5: 698 6: 1042 7: 942 8: 400 9: 400 10: 400 11: 896 12: 400 13: 747
14: 400 15: 1020 16: 400
~~~~~~~~~~~~~~~~~~~~~~~~~~~RAM~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Memory:
System RAM: total: 32 GiB available: 31.06 GiB used: 8.48 GiB (27.3%)
igpu: 60 MiB
Array-1: capacity: 64 GiB slots: 2 modules: 2 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: DDR4 size: 16 GiB
speed: 3200 MT/s
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 size: 16 GiB
speed: 3200 MT/s
~~~~~~~~~~~~~~~~~~~~~~~~~~~Storage~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Drives:
Local Storage: total: 1.82 TiB used: 677.67 GiB (36.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
Message: No optical or floppy data found.
~~~~~~~~~~~~~~~~~~~~~~~~~~~LVM~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Logical:
Device-1: VG: vgubuntu type: LVM2 size: 1.82 TiB free: 0 KiB
LV-1: Backup type: linear size: 100 GiB Components: p-1: nvme0n1p5
LV-2: Data type: linear size: 100 GiB Components: p-1: nvme0n1p5
LV-3: Documents type: linear size: 250 GiB Components: p-1: nvme0n1p5
LV-4: FedoraHome type: linear size: 18 GiB Components: p-1: nvme0n1p5
LV-5: FedoraRoot type: linear size: 100 GiB Components: p-1: nvme0n1p5
LV-6: FedoraSwap type: linear size: 32 GiB Components: p-1: nvme0n1p5
LV-7: Harddisk type: linear size: 660.64 GiB Components: p-1: nvme0n1p5
LV-8: Media type: linear size: 500 GiB Components: p-1: nvme0n1p5
LV-9: UbuntuHome type: linear size: 18 GiB Components: p-1: nvme0n1p5
LV-10: UbuntuRoot type: linear size: 50 GiB Components: p-1: nvme0n1p5
LV-11: UbuntuSwap type: linear size: 32 GiB Components: p-1: nvme0n1p5
~~~~~~~~~~~~~~~~~~~~~~~~~~~Graphics~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Graphics:
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: Realtek [] driver: uvcvideo type: USB
Display: server: X.Org v: 23.2.3 with: Xwayland v: 23.2.3 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915
resolution: 2256x1504~60Hz
API: OpenGL v: 4.6 vendor: intel mesa v: 23.3.1 renderer: Mesa Intel
Graphics (ADL GT2)
API: EGL Message: EGL data requires eglinfo. Check --recommends.
~~~~~~~~~~~~~~~~~~~~~~~~~~~Audio~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Audio:
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.6.7-200.fc39.x86_64 status: kernel-api
~~~~~~~~~~~~~~~~~~~~~~~~~~~Battery~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Battery:
ID-1: BAT1 charge: 31.0 Wh (60.2%) condition: 51.5/55.0 Wh (93.5%)
volts: 15.8 min: 15.4
~~~~~~~~~~~~~~~~~~~~~~~~~~~Bluetooth~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: 8C:F8:C5:ED:74:4C bt-v: 5.3
~~~~~~~~~~~~~~~~~~~~~~~~~~~Network~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Network:
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
IF: wlp166s0 state: up mac: 1a:35:8a:7f:96:29
- The top bar of my inbuilt laptop keyboard has media keys and some other functions. The media keys work as F1, F2, F3…,F12, when I press them along with the
fnkey.
I was on
Fedora Linux (6.5.10-300.fc39.x86_64) 39 (Workstation Edition)from past few months. From last week the function key on my laptopfnbecomes permanently pressed randomly after a couple of minutes of reboot . That means I am unable to play media keys as when I press those without pressingfnF1,…,F12 keys get activated. This fixes temporarily for few minutes after reboot. But again its the same issue. -
Today I updated to kernel:
6.6.7-200.fc39.x86_64and every software on my Fedora 39, but I am still facing the issue.
