Yes the problem repeats after reboot after couple days running without reboot - not sure about the root cause.
E.g. not right after the reboot but couple days after. My best guess is that its somehow connected with sleep mode.
I installed evtest, but it does show nothing when I press Fn button (both when Fn is not working, and when Fn is working after reboot) So it might not be the best tool for testing Fn stopping registering in the system.
F1+Fn and F1 has not difference when this issue happens. Below, copied output from evtest just turn on-turn off for F1+Fn as for F1 only its identical:
Event: time 1682197753.418585, type 4 (EV_MSC), code 4 (MSC_SCAN), value 38
Event: time 1682197753.418585, type 1 (EV_KEY), code 56 (KEY_LEFTALT), value 0
Event: time 1682197753.418585, -------------- SYN_REPORT ------------
Event: time 1682197753.430739, type 4 (EV_MSC), code 4 (MSC_SCAN), value 0f
Event: time 1682197753.430739, type 1 (EV_KEY), code 15 (KEY_TAB), value 0
Event: time 1682197753.430739, -------------- SYN_REPORT ------------
after reboot, Fn+F1 and F1 only - working correctly now:
Event: time 1682197870.238866, -------------- SYN_REPORT ------------
Event: time 1682197870.650673, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1682197870.650673, type 1 (EV_KEY), code 113 (KEY_MUTE), value 1
Event: time 1682197870.650673, -------------- SYN_REPORT ------------
Event: time 1682197870.799744, type 4 (EV_MSC), code 4 (MSC_SCAN), value a0
Event: time 1682197870.799744, type 1 (EV_KEY), code 113 (KEY_MUTE), value 0
Event: time 1682197870.799744, -------------- SYN_REPORT ------------
Event: time 1682197872.444981, type 4 (EV_MSC), code 4 (MSC_SCAN), value 3b
Event: time 1682197872.444981, type 1 (EV_KEY), code 59 (KEY_F1), value 1
Event: time 1682197872.444981, -------------- SYN_REPORT ------------
^[OPEvent: time 1682197872.562701, type 4 (EV_MSC), code 4 (MSC_SCAN), value 3b
Event: time 1682197872.562701, type 1 (EV_KEY), code 59 (KEY_F1), value 0
Please share more details how I can help you debugging / testing this problem.
