[RESPONDED] Hardware-based encryption (OPAL) vs. Fedora software-based encryption?
My DYI edition framework 13 will be arriving later today (AMD 7040 series).
I’m planning to install Fedora 39 on it, and in terms of storage options I got a Samsung 990 Pro SSD, which supports OPAL 2.0 self-encryption.
The question now is, should I rather go with the OPAL hardware encryption, or with the encryption Fedora offers at install (LUKS)? From what I’ve seen so far, the opinions seem pretty mixed:
Software-based encryption requires more processor work, slowing down the system (and therefore possibly draining more battery?).
Hardware-based encryption seems to avoid this problem, but there’s a lot of discussions over both hardware and software based encryption being possibly unsecure under certain circumstances. Software based via LUKS would be open source though, while the hardware based encryption is not. So now I’m unsure which to pick.
Any advice on which one you’d recommend for me? Thanks in advance!
OPAL Hardware based encryption is a lot better than nothing but these days the performance and battery drawbacks of real software based encryption has become so small you might as well just use that.
Unless your workload contains some absolutely brutal disk io where every extra mb/s counts I vote software based.
I will do the same and will use OPAL. The question is, what is your threat level? If someone steals your laptop, he will not try to decrypt it, your data is safe. If your threat level is the intelligence service, forget it: xkcd: Security
you can also use tailsOS with a USB stick/the extension module
Thanks for the replies!
@Adrian_Joachim
The workload would mainly be uni stuff (notes/coding/game engines) and maybe some light gaming, so that should probably not apply to me then.
@Bernd_Steinzimmer
Uni student. It’s basically just in case it gets stolen or lost, so my data isn’t immediately easily accessible
Samsungs OPAL is proven to be secure it latest generations. There are some hypothetical attacks, which required the laptop to be on. No thief will ever try to decrypt it. With OPAL you have the benefits of high speeds and decreased CPU load.
Yeah you’ll likely not even notice the performance difference
Welcome to the community, @MATOO!
We test against LUKS, but do not test against hardware implemented solutions. So based on that, for Fedora 39, LUKS would be my suggestion.
