Despite the lack of a TrackPoint, I’ve gone ahead and pre-ordered a DIY edition. However, I skipped the drive. Not because I have a spare gen4 nvme m.2 drive lying around, but because I’m holding out to source an Opal2 SED.
Wanted to put it out there, because I would order an SED with the laptop if it were an option. Does the UEFI firmware support enabling a boot-time unlock of an SED? Was this skipped for perceived lack of demand, or the lack of gen4 m.2 SEDs?
On the crazy side, I’d like to mutter about u.2 support for some truly fast storage, but I know, it wouldn’t fit in the chassis. Or probably the power envelope.
The firmware does take a hdd password and claims the SSD encryption has been enabled (rocking a 980 pro): I haven’t bothered to pull the drive and verify state independently. HDD password the firmware takes is relatively short. Maybe 8 characters? What I’m typing is a hell of a lot longer, but it only takes so many characters. One of these days I need to get around to actually stopping/counting that as well…
Then I could setup the encryption (for the samsung drive i needed to do a PSID revert first (see github Drive-Trust-Alliance/sedutil/issues/291) and github Drive-Trust-Alliance/sedutil/wiki/PSID-Revert) following the instructions here github Drive-Trust-Alliance/sedutil/wiki/Encrypting-your-drive.
Also the installation of the PBA on the shadowMBR was sucessful and booted.
Next I installed Kubuntu (following step-5-install-the-operating-system from the 13-tcg-opal-support.adoc)
After enabling locking again from the DTA rescue system I could sucessfully boot and unlock the ssd in the PBA, at the end the screen said sth like “loading OS”
only then… the system rebooted and I ended up in the PBA again. and again
Again, I made many more attempts to get the whole rear-stuff booting, but no luck
Then I found that the rear-OpalPBA-raw-img booted in quemu and from USB on the FW
so I rebooted my regular Kubuntu installation (after adding libata.allow_tpm=1 to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub and running sudo update-grub) and
used sedutil-cli to write the rear-PBA into the shadowMBR on the ssd
When booting up, the rear-PBA loaded nicely from the ssd shadowMBR - only it never accepted my password and rebooted after 5 failed attempts to unlock
At least I still had that DTA rescue system to disable the encryption/unlock the drive.
So that’s where I am - no more ideas and hoping for some community insights from more successful installations…
Thanks and best regards,
Raphael
PS: sorry I had to unlink some of the ressources being a new member here
@Mark_Coelho@Raphael Hey! Could you please answer if it worked for you and what you did? I too want to buy an SED for my new Frameworks DIY Laptop and want to use it with Ubuntu.
Could you also comment if you are able to do the firmware updates from Linux?
Hey Lamy,
yes, finally I made it, just didn’t find the time yet to write a detailed answer, hope to do that soon.
Very short hint:
The problem at this
point was, that the function tries to run a partprobe on the character device crw------- 1 root root 239, 0 Okt 13 19:49 /dev/nvme0
which fails. Instead it should run it on the block device brw-rw---- 1 root disk 259, 0 Okt 13 19:49 /dev/nvme0n1
This can be fixed in a q’n’d way by editing the rear scripts (before creating the rear-PBA img):
Hey Lamy,
no I didn’t do any firmware updates yet, seems I already got the latest release installed. Anyhow I collected some information just in case I will have or want to do any updates:
See info about your NVMe drive: sudo smartctl --info /dev/nvme0
In the output you can also see the number of namespaces, the 980 PRO has 1 - this actually is the number you can see in /dev/nvme0n1
@Lamy and @Raphael
I have my 980 Pro encrypted via the BIOS drive password. It appears to be using the underyling SED capabilities, but I haven’t really carefully dug into it. Just verified that sedutil-cli shows “encryption enabled” and the drive appears unreadable when placed in another system.
Basically, I let it become my daily-driver desktop much faster than expected and I haven’t done quite as much tinkering as I expected.
