[RESPONDED] Ubuntu 22.04: WIFI not working with AX211
Has anyone encountered activation blocking issues with AX211 on Ubuntu 22.4 , kernel 6.5.0-35-generi for WiFi 6E? If so, what steps have you taken to resolve it?
hi @jawharja ,
welcome to the community, can you describe more activation blocking? Is the wifi visible on Ubuntu 22.04 ? or is it an intermittent connection issue with AX211?
Hi,
Which motherboard are you trying to use the AX211 in?
FYI: the AX211 only works in Intel motherboards.
The AX210 works in AMD motherboards.
