RGB keyboard configuration
I’m not normally a fan of RGB keyboards, but the engineering sample shown in DAVE2D’s video looks very well done. I think most of the time I’d want to keep it a static color, just a different color. A wave would be too distracting when I’m working. :sweat_smile:
The product page for the Framework Laptop 16 provides this description for the RGB keyboard:
US English keys with an RGB backlight. Use hotkeys or QMK utilities to cycle through lighting effects.
I’ve never used a keyboard with QMK firmware before. Searching around the internet, the only utility I can find is used for loading a custom keymap, not for setting different LED colors or patterns.
Are there already user-friendly GUIs out there for setting LEDs on keyboards with QMK firmware? Does Flamework plan on releasing such a tool? I found Framework’s GitHub repository for the keyboard firmware, but that doesn’t tell me what APIs might be used to set colors.
Careful there, dude :wink:
As per:
Maybe I’m misunderstanding, but is there something wrong with talking about Framework’s plans? Some plans are known and confirmed. Even have code on their github.
~edit~
Oh, I completely missed the “Flamework” typo! :smile:
Oh no, not at all!
I was just joking about the typo!
It made me laugh - and reminded me of the time I accidentally called my friend (Stacy) “Spacy” (which she definitely was not!).
Oh, I completely missed the typo! :smile:
I missed the typo too and was also confused about that initial response :sweat_smile:
As I’m learning more about Via, I’m not crazy about a remote web application that has control over part of my hardware settings. That makes me uncomfortable from a security perspective and means that I couldn’t make changes while offline. Even their client releases are just wrappers that point to the remote web app.
Yeaa, a lot of people aren’t a fan of that. And to be honest, in my opinion, the Via developers are not a great bunch. Via has a history of being difficult and uncooperative with QMK, which Via is based on and also fully dependent on. So difficult that it pushed QMK devs forward to work on their own GUI. And Via was originally closed source. Currently, it’s open source, perhaps pushed to it by the threat of Vial taking all their users.
But I really do think we’ll see Vial firmware pretty quickly. Hopefully, Framework will realize that Vial better aligns with their philosophy. But if not, the community will probably do it. Hell, I might do it. Even though I don’t have a FW-16 on order.
I think there is a way to run the Via web app locally, without an internet connection. But eh, it’s still not great.
Framework support had this to say:
Thank you for reaching out and for your patience, we’ll be releasing more documentation and guides on the RGB Keyboard in the near future showing how to adjust mappings and behavior using the VIA website, but the simplest way to configure the RGB behavior will be directly on the Keyboard, whilst holding the Function key the following keys will adjust the backlight behavior:
RGB and White Backlight variants:
  • Space = Step through backlight brightness levels
RGB Backlight:
  • W = RGB animation on/off
  • E = Next animation
  • D = Prev animation
  • R = Increase RGB Hue (doesn’t apply to all animations)
  • F = Decrease RGB Hue (doesn’t apply to all animations)
  • T = Increase RGB Saturation (doesn’t apply to all animations)
  • G = Decrease RGB Saturation (doesn’t apply to all animations)
  • Y = Increase RGB Brightness
  • H = Decrease RGB Brightness
  • U = Increase RGB Brightness
  • J = Decrease RGB Brightness
One of the default animations available will be “Solid Color” which does exactly what you’d expect, and sets all keys to a single static color (which can be adjusted either within VIA’s web interface or using the keys above).
I have decided to stay with the standard backlit keyboard.
Oh yea, sorry, I forgot to mention that controlling the RGB color and patterns could be done from the keyboard via hotkeys.
You can see the default key arrangement on Framework’s github.
     * Function layer
     * 14 keys │FN lk│Mut│vDn│vUp│Prv│Ply│Nxt│bDn│bUp│Scn│Air│Prt│App│Ins │
     * 14 keys │   │   │   │   │   │   │   │   │   │   │   │   │   │      │
     * 14 keys │     │   │RGB│Nxt│Hue│Sat│Spd│Brt│   │   │Pau│   │   │    │
     * 13 keys │      │   │SRq│Prv│Hue│Sat│Spd│Brt│ScL│   │   │   │       │
     * 12 keys │        │   │   │   │   │   │Brk│   │   │   │   │         │
     *         │    │   │   │   │                   │   │   │    │PgU│    │
     * 11 keys │    │   │   │   │ Toggle Backlight  │   │   │Home├───┤End │
     *         │    │   │   │   │                   │   │   │    │PgD│    │
     * 78 total
    [_FN] = LAYOUT(
        FN_LOCK, KC_MUTE, KC_VOLD, KC_VOLU, KC_MPRV, KC_MPLY, KC_MNXT, KC_BRID, KC_BRIU, KC_SCRN, KC_AIRP, KC_PSCR, KC_MSEL, KC_INS,
        _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______, _______,
        _______, _______, RGB_TOG, RGB_MOD, RGB_HUI, RGB_SAI, RGB_SPI, RGB_VAI, _______, _______, KC_PAUS, _______, _______, _______,
        _______, _______, KC_SYRQ, RGB_RMOD,RGB_HUD, RGB_SAD, RGB_SPD, RGB_VAD, KC_SCRL, _______, _______, _______,          _______,
        _______,          _______, _______, BL_BRTG, _______, KC_BRK,  _______, _______, _______, _______, _______,          _______,
        _______, _______, _______, _______,          BL_STEP,                   _______, _______, KC_HOME, KC_PGUP, KC_PGDN, KC_END
Of course, that’s not guaranteed to be the final arrangement they ship with. And you can always change anything you wish.
I think there is a typo / error with the Y and H keys in the list they gave. One, Increase and Decrease RGB Brightness appear twice.
Two, the FW16 code shows that instead those keys would be:
Y= Increase Effect Speed (animations)
H = Decrease Effect Speed (animations)
What key does one initially press to do anything with that mapping of hotkeys— oh! It’s the fn key.
fn space controls the keyboard backlight— but not the number pad which stays stubbornly lit at full strength.
Any updates on documentation of this feature or what programs we can install to control keypad colors? Want to make the keyboard and numpad red. (If it supports that, i had thought i had gotten the keyboards with no lights at all, but in trying to tone down or turn red the numpad i just found out now that my keyboard has, at the least, a backlight.)
Thanks!
frame.work/laptop-16-support. Links to software and documentation can be found there.
Numlock on + numpad-enter will cycle numpad brightness.
The keyboards can’t communicate with each other. Each keyboard acts as a standard USB HID keyboard. And USB HID doesn’t provide a way for one keyboard to send arbitrary commands to another.
Full color is only available if you bought a keyboard with RGB in it’s name, or the macropad. All other keyboards have a normal white backlight.
The whole "Configure your LED Matrix/RGB Keyboard/Macropad via a web page application is to say the least - not great. I’m guessing they’re trying to achieve a cross platform windows/linux functionality by putting it in the browser. The browser decided to fight me all the way - refusing to connect because “security”. I want a command line linux utility that I can tell the keyboard what to do and a C API if I want to integrate control in my own programs - which is where it gets useful because I can highlight context relevant keys.
I can compare this to the Adafruit RBG macropad, which is a marvellous thing. It runs circuit-python on the keypad and the code it runs appears as a USB drive. To edit the code, just edit the file on the USB drive. I coded up a secure challenge response login mechanism with the adafruit macropad because I could just drop in X25519 and Ed25519 into the macropad and have it take in a password, derive keys and type the challenge and take the response via code I’d written. It was glorious. Not so much with the Framework keyboards which are tied to QMK and all the complexity and issues that come with that.
Pardon? :thinking:
Seems you missed the fact that the Framework keyboards use the exact same rp2040 mcu as your Adafruit RBG macropad. All the features you mention, circuit-python, appearing as a USB drive, editing a file & just dropping it in, are there.
Tied to QMK? There are keyboards running QMK proper that are tied to the open source QMK firmware? :upside_down_face: As in, the manufacturer does something to prevent flashing your own code? Write protects, blows efuses, whatever other tivoization. Parts of QMK are GPLv3, which any manufacturer who attempts tivoization would be violating. Yeah, Framework don’t do that.
Want to write some circuit-python, or otherwise create your own keyboard firmware, have at it.
I’m considering it. However I do have a bunch of other open source programs I wrote that I need to maintain. So I’m not spending much time trying to make the Framework RGB keyboard work as nicely as the adafruit one. I have designed and built my own keyboards and I made those have a nice interface like adafruit’s. So I have the skills. I’m just limited on time.
Framework is limited on time and effort as well. Plus, they are a hardware company. So it was going to be one of the already available open source keyboard firmwares. Of which the most mature, feature full and widely used are qmk and zmk. And zmk is focused mostly on bluetooth battery powered keyboards.
Framework did create a small command line linux utility, see their github repositories. Though I don’t believe it currently does everything you see to be looking for.
The browser-based keyboard config system is called Via. It’s is not really qmk, not made by the same devs. Can’t say I’m a fan of it either. Perhaps you would like Vial better. https://get.vial.today. Desktop apps for linux, windows, mac, in addtion to a browser-based option. Offers more configuration options that Via too. A community member created a qmk/Vial firmware for one or more Framework keyboards. Thread should come up searching Vial.
