Risc-v desktop
The description of RISC-V mainbord says it works with the Framework Desktop, but I don’t see any way to purchase it without buying the whole desktop with one one of X86 mainboards.
Would be great if there was an option to either buy the whole chassis separately or buy RISC-V as a desktop configuration option.
Sounds like a mistake. The desktop takes standard Mini-ITX mainboards while the RISC-V is in a custom format for the Framework 13 laptop.
It was the blog, not the description, oh well.
But the same applies to the laptop, only available selections are Intel or AMD
OK, that’s the mainboard, so where can I buy a chassis without Intel or AMD?
Or, if you don’t want a laptop:
