Screen and keyboard backlight stay on after closing the lid (intermittent)
I have noticed that sometimes when I close the lid, the screen and the keyboard backlight turn on and stay on. This can only be seen in a dark room and if you have a transparent bezel. I know no one likes an intermittent problem, but when this starts I have to reboot the laptop to avoid wasting the battery. The lid-closed action is set to suspend on both AC and battery power.
Also, when the problem starts, I have tested it by holding a magnet on top of the left-hand Shift key, and the screen locks, blinks, and comes back on, asking for a password. I am assuming this is what happens when the lid is closed.
I have 13 Pro intel Ultra X7 on BIOS 3.02And running on it Linux MINT 22.3 - Cinnamon on kernel 7.0.0-38 generic
Here is what it looked like when I first noticed it. This is with the lid closed, and you are seeing light from the transparent bezel.
This is a pain… if anyone can find a solution, it would be great. I have to shut it down when I see light shining through the lid on my desk after I turn the room light off to go to bed.
Update: found the cause. It’s the Bluetooth controller breaking suspend, not the lid.
The Intel Bluetooth PCIe controller (btintel_pcie, 0000:00:14.7) gets wedged. After that, every suspend is aborted by the kernel, logind gives up, and the lid stays closed with the machine still awake. The magnet test only showed that the lid switch event reaches the OS fine.
Suspend worked until Oct 11, including about 13 hours of s2idle overnight. About two minutes after that long resume, the first error appeared:
Bluetooth: hci0: Failed to get mac access: (-62)
Every suspend after that failed:
Bluetooth: hci0: Timeout (200 ms) on alive interrupt for D2 entry, retry count 2
btintel_pcie 0000:00:14.7: PM: btintel_pcie_suspend returns -16
PM: Some devices failed to suspend, or early wake event detected
systemd-sleep: Failed to put system to sleep. System resumed again: Device or resource busy
I confirmed it by reloading the driver without rebooting (modprobe -r btintel_pcie, then modprobe btintel_pcie). The next lid close suspended normally.
This looks like a driver/firmware bug in btintel_pcie (Framework 13 Pro, kernel 7.0.0-38-generic, BT firmware build 2025.46). If anyone can pass this to the Framework or Intel Bluetooth people, that would be great. If you have the same symptom, check with:
journalctl -b | grep -E "btintel|Failed to put system to sleep"
(Written and formatted with AI help, at 2 AM.)
I found that the issue is sometimes linked to my earbuds. I’m not fully certain, but I think it’s because they’re connected to multiple devices.
An easier way to fix this is to turn off Bluetooth on the computer; then closing the device works fine.
Hopefully Linux Mint 27 fixes it.
