This is more of a heads-up for those using Framework 16 (Ryzen 7040 Series) on any linux distro (as far as I could tell). I’ve been encountering a very annoying screen flickering issue (rare horizontal stripes on the screen go in crazy colors for a fraction of a second a few times every several minutes). Very annoying, not very consistent and/or easy to reproduce.
For me, the problem occured on Arch, and later on NixOS 24.11. I also tried different compositors (picom, mutter) and desktop environments (hyprland, sway, gnome), both on Wayland and X11 – all the same. BIOS update also didn’t yield any positive results (currently I’m on the 3.05). This occurs also both with and without the discrete AMD 7700s GPU attached.
The problem started occuring roughly in November, after a system kernel update on my then-daily-driver Arch, and persisted after I switched to NixOS, on which I was using pkgs.linuxPackages_latest (which was using 6.12).
The solution was to roll back to an earlier linux kernel (currently I use pkgs.linuxPackages_6_6, but I think the issue might have started from 6.11 onward). Would be great to know if anyone else has encountered this issue, or knows if there is any open issue in the linux kernel dev community?
