Slightly bent CPU heatsink when switching out Liquid Metal to PTM - How bad is it?
When i switched out Liquid Metal to PTM and pried up the heatsink i slightly bent my heatsink (See pics). I could install everything back to normal and i do get a nice bump from 12000 (liquid metal) to 14400 Points (PTM) in Cinebench R23 and from about 33W to 55W Initially - however the 55W dropped consistently to about 47W at the end of the test so im a bit worried that this was caused by the heatsink issue struggling to remove the heat.
Am I beeing paranoid or could this be the case ?
Also any Cinebench Results for Multicore without GPU for comparison would be highly appreciated if you got the PTM. I read in the other thread people are able to achieve about 16k points.
I slightly bent my own when I did the LTT PTM7950 install on my own machine last September. Like you, I was worried, but so far it’s been fine.
It’s fine, I bent the right pipes a bit while disassembling the first time because I missed the 2 screws that aren’t immediately obvious, bent them back, no impact on cooling performance.
There are FW provided instructions on how to remove the heat sink now. It says where to pry the heat sink up without damaging it and where the 5 screws are.
It’s the LM → PTM one in the “guides” section.
