What Samsung M.2 SSDs are compatible? I’m looking at installing a 980 pro
I think any 2280 M.2 gen 3 or 4. For best battery life use gen 3, the SK Hynix P31 has the best efficiency, I use the 980 Pro works fine efficiency is decent but not as good as the P31 Gold
Answer provided above, marking as solved.
