What specific types of storage does the Framework support? I can’t find any references on the site for the supported specs.
Specifically, I’m trying to figure out if my m.2 2280 SATA (which fits in the socket) will work.
It supports a M-key M.2 NVMe drive of 2280 sizing (the most common size, and I don’t believe there are mounting screw points for smaller sizes). It has 4x PCIe 4.0 lanes on this connector, backwards compatible with older PCIe versions.
M.2 SATA drives are not supported.
From the online documentation:
M.2 You can use M.2 2280-sized NVMe SSDs. We have drives from 250GB up to 4TB available in the Framework Marketplace, and drives ranging from 128GB to 8TB are available in the market. While drives from other brands should work, we’ve focused our compatibility testing on the following ones:
Note that SATA M.2 drives will not work on the Framework Laptop with 11th Gen Intel Core Processors. You will need to use an NVMe drive, which we would recommend anyway due to the significant performance improvements that brings.
Thanks for the info! Is SATA and NVMe support mutually exclusive (meaning if something supports one, then it cannot support the other)?
In principle some computers could have M-key M.2 slots that support both SATA and PCIe/NVMe modes (there are config pins to inform the system which type it is), but it seems like a rarity in my experience, at least in recent times. I’ve not personally used a computer that supported both SATA and NVMe in one M.2 slot, but I assume that such exist since the connector standard is designed to allow that.
I think the majority of desktop motherboard M.2 slots support both standards, but it just seems either Tiger Lake doesn’t have a SATA controller, or Framework hasn’t enabled/supported it.
The PCI-e Gen4 interface on Tiger Lake doesn’t support SATA over the same interface, so we chose to support NVMe 4.0 and no SATA instead of a slower NVMe with SATA.
I have an older WD SN720 I’m not using. Will it work?
Should work without issues
With 12th Gen Intel® Core™ DIY Edition there is no SN750 (250GB) option any more … is it still compatible?
There should be no reason it’s not compatible, it’s just that 250 GB drives are getting hard to find lately so they may have skipped stocking them.
