What Operating System and Distribution I’m running on…
Pop!_OS 22.04 LTS (Linux).
What is the problem…
My Internal Wifi-Apter won’t work any more.
What caused the issue…
I removed the chip and installed a different one and now both won’t work after Installing both.
How long have I had this Issue…
What did I try to fix the Issue…
I Tried re-plugging the cables.
I switch the new chip for the old one.
Hi @Andrew_Pflanzer ,
just to check if it’s not only happening in Pop!_OS, can you also try Ubuntu live USB?
thanks
Be_Far
April 29, 2023, 4:58pm
3
what are the outputs of modinfo iwlwifi and dmesg | grep iwlwifi? the first will check if the wifi driver is loaded, and the second will let you know if it’s experiencing any errors.
To @Be_Far and @Loell_Framework
I’ve got it to work now, thank you for the help anyways.
It just started working for some reason.
