Spotlight, stick on laptop stands
Not sure if this is the right place or format but I got these stick on laptop stands for my FW16 and they are pretty sweet given the price. Matches the finish color of the laptop, fits perfectly into a blank area of the laptop, and now I don’t need to use my desktop laptop stand or worry about cooling when I’m not at home. https://a.aliexpress.com/_mrWq9DS
Nice finish ! Does the rear skate still contact the surfaces when the feet are not extended?
It’s soooo close, but just barely the stand is contacting before the skate. If you took off the bumper on the stick on stand, it might contact the skate first but I don’t know for sure.
Thank you, I was curious, still clearly affordable lol
One thing I really like about the framework 16 is that is also pulls air in from the top of the chassis, so even if the bottom is entirely blocked it can still get good airflow.
Hey that’s cool. I did the same thing to mine with Nillkin brand ones on Amazon, for the rubber feet vs straight metal. They do fit pretty nicely in that little space there, but I did notice that when running it hard it softened up the adhesive a bit and sometimes allowed them to slip a little.
It also only raises it slightly higher than standard while not folded out.
These are plastic construction. I saw your post about those other ones and I figured they were also plastic. Glad to hear they are actually metal though! It inspired me to find them on AliExpress and I settled on these instead:)
