If you’ve been wanting to run LLMs locally on your Framework Desktop but weren’t sure where to start — I put together a walkthrough that covers the full setup from scratch.
The guide walks through:
UEFI settings to get the iGPU memory working correctly
Installing the right kernel and firmware versions (there are a few version-specific pitfalls to avoid)
ROCm 7.2.1 driver setup
Building and running a llama.cpp server
It also works on any machine with an AMD Ryzen AI Max series APU, not just the Framework Desktop.
A Traditional Chinese version is also available in the same repo.
I know AMD GAIA and lemonade, but the whole point of this guide is to install ROCm driver/runtime and choose stable kernel and firmware. git pull and build llama.cpp from source is easy, also it gives you latest ROCm runtime, bugfix/improvements and best performance.
