Also here’s the output of dmesg when the display is working:
[ 39.698810] thunderbolt 1-0:3.1: new retimer found, vendor=0x8087 device=0x15ee
[ 40.348846] thunderbolt 1-3: new device found, vendor=0x1e device=0x1114
[ 40.348857] thunderbolt 1-3: LG Electronics UltraFine 5K
[ 40.599036] pcieport 0000:00:07.3: pciehp: Slot(6): Card present
[ 40.599040] pcieport 0000:00:07.3: pciehp: Slot(6): Link Up
[ 40.730718] pci 0000:7d:00.0: [8086:15ef] type 01 class 0x060400
[ 40.730856] pci 0000:7d:00.0: enabling Extended Tags
[ 40.731175] pci 0000:7d:00.0: supports D1 D2
[ 40.731180] pci 0000:7d:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 40.731377] pci 0000:7d:00.0: PTM enabled, 4ns granularity
[ 40.731421] pci 0000:7d:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.3 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 40.731805] pci 0000:7d:00.0: Adding to iommu group 17
[ 40.732089] pcieport 0000:00:07.3: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 40.740659] pci 0000:7d:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 40.740888] pci 0000:7e:02.0: [8086:15ef] type 01 class 0x060400
[ 40.740989] pci 0000:7e:02.0: enabling Extended Tags
[ 40.741222] pci 0000:7e:02.0: supports D1 D2
[ 40.741225] pci 0000:7e:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 40.741464] pci 0000:7e:02.0: Adding to iommu group 18
[ 40.741742] pci 0000:7d:00.0: PCI bridge to [bus 7e-a5]
[ 40.741757] pci 0000:7d:00.0: bridge window [io 0x0000-0x0fff]
[ 40.741765] pci 0000:7d:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 40.741778] pci 0000:7d:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 40.741784] pci 0000:7e:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 40.741959] pci 0000:7f:00.0: [8086:15f0] type 00 class 0x0c0330
[ 40.742001] pci 0000:7f:00.0: reg 0x10: [mem 0x00000000-0x0000ffff]
[ 40.742115] pci 0000:7f:00.0: enabling Extended Tags
[ 40.742353] pci 0000:7f:00.0: supports D1 D2
[ 40.742357] pci 0000:7f:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 40.742522] pci 0000:7f:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:07.3 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 40.742655] pci 0000:7f:00.0: Adding to iommu group 19
[ 40.742891] pci 0000:7e:02.0: PCI bridge to [bus 7f-a5]
[ 40.742906] pci 0000:7e:02.0: bridge window [io 0x0000-0x0fff]
[ 40.742915] pci 0000:7e:02.0: bridge window [mem 0x00000000-0x000fffff]
[ 40.742929] pci 0000:7e:02.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 40.742935] pci_bus 0000:7f: busn_res: [bus 7f-a5] end is updated to 7f
[ 40.742948] pci_bus 0000:7e: busn_res: [bus 7e-a5] end is updated to 7f
[ 40.742972] pci 0000:7d:00.0: BAR 14: assigned [mem 0x52000000-0x5e1fffff]
[ 40.742978] pci 0000:7d:00.0: BAR 15: assigned [mem 0x6060000000-0x607bffffff 64bit pref]
[ 40.742984] pci 0000:7d:00.0: BAR 13: assigned [io 0x7000-0x7fff]
[ 40.742991] pci 0000:7e:02.0: BAR 14: assigned [mem 0x52000000-0x5e1fffff]
[ 40.742997] pci 0000:7e:02.0: BAR 15: assigned [mem 0x6060000000-0x607bffffff 64bit pref]
[ 40.743002] pci 0000:7e:02.0: BAR 13: assigned [io 0x7000-0x7fff]
[ 40.743008] pci 0000:7f:00.0: BAR 0: assigned [mem 0x52000000-0x5200ffff]
[ 40.743020] pci 0000:7e:02.0: PCI bridge to [bus 7f]
[ 40.743026] pci 0000:7e:02.0: bridge window [io 0x7000-0x7fff]
[ 40.743039] pci 0000:7e:02.0: bridge window [mem 0x52000000-0x5e1fffff]
[ 40.743048] pci 0000:7e:02.0: bridge window [mem 0x6060000000-0x607bffffff 64bit pref]
[ 40.743063] pci 0000:7d:00.0: PCI bridge to [bus 7e-7f]
[ 40.743069] pci 0000:7d:00.0: bridge window [io 0x7000-0x7fff]
[ 40.743080] pci 0000:7d:00.0: bridge window [mem 0x52000000-0x5e1fffff]
[ 40.743090] pci 0000:7d:00.0: bridge window [mem 0x6060000000-0x607bffffff 64bit pref]
[ 40.743104] pcieport 0000:00:07.3: PCI bridge to [bus 7d-a5]
[ 40.743110] pcieport 0000:00:07.3: bridge window [io 0x7000-0x7fff]
[ 40.743118] pcieport 0000:00:07.3: bridge window [mem 0x52000000-0x5e1fffff]
[ 40.743125] pcieport 0000:00:07.3: bridge window [mem 0x6060000000-0x607bffffff 64bit pref]
[ 40.743176] pcieport 0000:7d:00.0: enabling device (0000 -> 0003)
[ 40.743763] pcieport 0000:7e:02.0: enabling device (0000 -> 0003)
[ 40.745141] pci 0000:7f:00.0: enabling device (0000 -> 0002)
[ 40.745856] xhci_hcd 0000:7f:00.0: xHCI Host Controller
[ 40.745865] xhci_hcd 0000:7f:00.0: new USB bus registered, assigned bus number 5
[ 40.747194] xhci_hcd 0000:7f:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
[ 40.747676] xhci_hcd 0000:7f:00.0: xHCI Host Controller
[ 40.747680] xhci_hcd 0000:7f:00.0: new USB bus registered, assigned bus number 6
[ 40.747684] xhci_hcd 0000:7f:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 40.747748] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.00
[ 40.747751] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 40.747753] usb usb5: Product: xHCI Host Controller
[ 40.747755] usb usb5: Manufacturer: Linux 6.0.11-arch1-1 xhci-hcd
[ 40.747757] usb usb5: SerialNumber: 0000:7f:00.0
[ 40.747917] hub 5-0:1.0: USB hub found
[ 40.747930] hub 5-0:1.0: 2 ports detected
[ 40.748518] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.00
[ 40.748523] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 40.748527] usb usb6: Product: xHCI Host Controller
[ 40.748530] usb usb6: Manufacturer: Linux 6.0.11-arch1-1 xhci-hcd
[ 40.748532] usb usb6: SerialNumber: 0000:7f:00.0
[ 40.749485] hub 6-0:1.0: USB hub found
[ 40.749498] hub 6-0:1.0: 2 ports detected
[ 40.997297] usb 5-2: new high-speed USB device number 2 using xhci_hcd
[ 41.141712] usb 5-2: New USB device found, idVendor=043e, idProduct=9a61, bcdDevice=52.50
[ 41.141731] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 41.141737] usb 5-2: Product: USB2.1 Hub
[ 41.141742] usb 5-2: Manufacturer: LG Electronics Inc.
[ 41.143329] hub 5-2:1.0: USB hub found
[ 41.146651] hub 5-2:1.0: 4 ports detected
[ 41.261121] usb 6-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 41.284734] usb 6-1: New USB device found, idVendor=043e, idProduct=9a60, bcdDevice=52.50
[ 41.284764] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 41.284777] usb 6-1: Product: USB3.1 Hub
[ 41.284785] usb 6-1: Manufacturer: LG Electronics Inc.
[ 41.287870] hub 6-1:1.0: USB hub found
[ 41.288404] hub 6-1:1.0: 4 ports detected
[ 41.450654] usb 5-2.4: new high-speed USB device number 3 using xhci_hcd
[ 41.565158] usb 5-2.4: New USB device found, idVendor=043e, idProduct=9a73, bcdDevice= 1.00
[ 41.565173] usb 5-2.4: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 41.565178] usb 5-2.4: SerialNumber: A40B0061C847
[ 41.567136] hub 5-2.4:1.0: USB hub found
[ 41.567243] hub 5-2.4:1.0: 3 ports detected
[ 41.637506] usb 6-1.4: new SuperSpeed USB device number 3 using xhci_hcd
[ 41.655223] usb 6-1.4: New USB device found, idVendor=043e, idProduct=9a71, bcdDevice= 1.00
[ 41.655236] usb 6-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 41.657671] hub 6-1.4:1.0: USB hub found
[ 41.657731] hub 6-1.4:1.0: 3 ports detected
[ 41.847253] usb 5-2.4.1: new high-speed USB device number 4 using xhci_hcd
[ 41.960599] usb 5-2.4.1: New USB device found, idVendor=043e, idProduct=9a66, bcdDevice= 0.03
[ 41.960619] usb 5-2.4.1: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 41.960627] usb 5-2.4.1: Product: LG UltraFine Display Audio
[ 41.960632] usb 5-2.4.1: Manufacturer: LG Electronics Inc.
[ 42.014028] usb 6-1.4.3: new SuperSpeed USB device number 4 using xhci_hcd
[ 42.031212] usb 6-1.4.3: LPM exit latency is zeroed, disabling LPM.
[ 42.031885] usb 6-1.4.3: New USB device found, idVendor=043e, idProduct=9a68, bcdDevice= 2.23
[ 42.031896] usb 6-1.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 42.031902] usb 6-1.4.3: Product: LG UltraFine Display Camera
[ 42.031907] usb 6-1.4.3: Manufacturer: LG Electronlcs Inc.
[ 42.035574] usb 6-1.4.3: Found UVC 1.10 device LG UltraFine Display Camera (043e:9a68)
[ 42.051284] input: LG UltraFine Display Camera as /devices/pci0000:00/0000:00:07.3/0000:7d:00.0/0000:7e:02.0/0000:7f:00.0/usb6/6-1/6-1.4/6-1.4.3/6-1.4.3:1.0/input/input27
[ 42.054253] hid-generic 0003:043E:9A68.0008: hiddev97,hidraw3: USB HID v1.01 Device [LG Electronlcs Inc. LG UltraFine Display Camera] on usb-0000:7f:00.0-1.4.3/input2
[ 42.120555] usb 5-2.4.2: new full-speed USB device number 5 using xhci_hcd
[ 42.213812] usb 5-2.4.2: New USB device found, idVendor=043e, idProduct=9a70, bcdDevice= 4.13
[ 42.213837] usb 5-2.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 42.213845] usb 5-2.4.2: Product: LG UltraFine Display Controls
[ 42.213846] usb 5-2.4.2: Manufacturer: LG Electronics Inc.
[ 42.234467] hid-generic 0003:043E:9A70.0009: hiddev98,hidraw4: USB HID v1.11 Device [LG Electronics Inc. LG UltraFine Display Controls] on usb-0000:7f:00.0-2.4.2/input0
[ 42.235992] hid-generic 0003:043E:9A70.000A: hiddev99,hidraw5: USB HID v1.11 Device [LG Electronics Inc. LG UltraFine Display Controls] on usb-0000:7f:00.0-2.4.2/input1
[ 42.237879] hid-generic 0003:043E:9A70.000B: hiddev100,hidraw6: USB HID v1.11 Device [LG Electronics Inc. LG UltraFine Display Controls] on usb-0000:7f:00.0-2.4.2/input2
Also firmware version of the display:
$ cat /sys/bus/thunderbolt/devices/1-3/nvm_version
43.0
