I was trying to follow the guide with suspend then hibernate but whenever I try to install the extension nothing ever seems to happen. I am stuck at this screen:
Hi
What distro are you trying to install?, what guide are you following?
/Zoe
Fedora 42 workstation, and I was following the official guide ( linux-docs/hibernation/hibernate-fedora-automatic.md at main · FrameworkComputer/linux-docs · GitHub ).
I later on saw that in Gnome Extensions I got an error code that I could post here. I‘ll do that later.
This is the error message I got:
GLib.FileError: Failed to open file “/home/jokel/.local/share/gnome-shell/extensions/hibernate-status@dromi/schemas/gschemas.compiled”: open() failed: No such file or directory
Stack trace:
getSettings@resource:///org/gnome/Shell/Extensions/js/extensions/sharedInternals.js:101:53
Prefs@file:///home/jokel/.local/share/gnome-shell/extensions/hibernate-status@dromi/prefs.js:24:30
_loadPrefs@resource:///org/gnome/Shell/Extensions/js/extensionPrefsDialog.js:40:26
asyncExtensionPrefsDialog@resource:///org/gnome/Shell/Extensions/js/extensionPrefsDialog.js:28:14
OpenExtensionPrefsAsync@resource:///org/gnome/Shell/Extensions/js/extensionsService.js:138:33
asyncLaunchExtensionPrefsAsync@resource:///org/gnome/Shell/Extensions/js/extensionsService.js:125:14
_handleMethodCall@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:373:35
_wrapJSObject/<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:408:34
_init/GLib.MainLoop.prototype.runAsync/</<@resource:///org/gnome/gjs/modules/core/overrides/GLib.js:263:34
excuse my absence.
can you please repeat the configure hibernate step and check for errors?
/Zoe
for extra credit you can continue to go one step back at a time and check for errors, or repeat the guide from the top being on the lookout for any errors, if you feel inclined.
chatGPT gave the following suggestion:
glib-compile-schemas ~/.local/share/gnome-shell/extensions/hibernate-status@dromi/schemas/
and it actually worked
Edit:
Am I correct that now, if I close the lid (which I have set to suspend), it will eventually go into hibernation (in my case I have set it to 900 sec e.g. 15min)?
Okay, I can confirm that it is not working yet. Did anyone else configure this successfully on the FW12?
I just checked my log from today:
Oct 22 17:11:55 fedora systemd-sleep[43138]: Performing sleep operation 'suspend'...
Oct 22 20:12:04 fedora kernel: printk: Suspending console(s) (use no_console_suspend to debug)
I think your best bet is to follow the guide from the top, and listen to reported errors.
based on what you have shared I believe you are missing some configurations.
