Good morning,
Usually every Sunday I make backup copies using ventoy+acronis. In a simplified way, I clone the entire hard drive into another exactly the same one.
This way if the disk breaks I just have to open framework13, replace the disk and continue working.
With the Windows update I have not been able to boot using Ventoy due to the following error:
Verifying shim SBAT data failed: Security Policy Violation
Something has gone seriously wrong: SBAT self-check failed: Security Policy Violation
Given the impossibility of booting through the Ventoy USB, I had to disable secure boot using the F2 key.
Finally I was able to boot, make the copy. Later I enabled secure startup again to leave it as it was previously but… surprise…
The pin and fingerprint did not allow them to be used, because window had detected a change in security… I had to log in with a password.
I have had to reconfigure the pin and fingerprint as if the computer were new.
Every time I want to clone the disk will I have to do all this?
Thanks for all.
