Which kernel are you using? 6.16.4-108.bazzite.fc42.x86_64
Which BIOS version are you using? 3.05
Which Framework Laptop 12 model are you using? (13th Gen Intel® Core™)
Hi, I already contacted support about this, but maybe someone knows something.
My Framework 12 recently arrived and I set up Windows and Bazzite in a dual boot scenario.
On Windows tablet mode works fine, but on Bazzite I can’t get it work. Folding the display back displays the keyboard, but the OSK does not appear and auto-rotate does not work either.
Today it worked one time, but no idea what was different that timel. I also tried Bluefin with the same behaviour.
Does anyone know if I missed something or is there an issue with my hardware?
See the tablet mode event which corresponds to when I folded the display
I don’t really know how this hardware event ends up getting signaled to the desktop environment though.
In gnome, you can toggle auto-rotate on and off with Super+o or in the top right popup when in tablet mode. Perhaps somehow auto-rotate is set to off for you?
I’m still suspecting some kind of hardware issue because I have been able to get a ~80% success rate switching into tablet mode by holding the laptop at a very specific angle while folding it back. This makes me think one of the sensors is reporting abnormally.
Like above, the keyboard reliably locks out and framework tool reports the tablet mode, but the OSK and auto-rotate don’t reliably enable. Also sudo libinput debug-events | grep SWITCH_TOGGLE only reports the event on times I successfully switch to tablet mode.
Perhaps Windows is using slightly different logic to do the transition.
I also have a ticket open with support and will report back any findings.
