Do we think the move is to use TLP?
TLP is a feature-rich command line utility for Linux, saving laptop battery power without the need to delve deeper into technical details.
https://linrunner.de/tlp/introduction.html
I plan to roll nixos.
Yes, TLP helped with my battery life, and I would highly recommend it. Elsewhere on this forum, people have compared power-profiles-daemon to TLP and found that TLP does a better job of reducing power consumption. Keep in mind that you may have to uninstall power-profiles-daemon on certain distros, since it may be installed by default and it will conflict with TLP.
Some people recommended auto-cpufreq as well, has anyone tried both and can recommend one of the two over the other? It should be noted though that according to the documentation of auto-cpufreq, you can actually run both at the same time, so maybe that’s the best option.
Since it’s not available in the Debian repos, I haven’t (yet) tried it. TLP has given me enough battery life that I’m not particularly inclined to mess around with other stuff just yet.
Thanks for this thread - installed TLP, referencing the excellent doc at Introduction — TLP 1.5 documentation. Very good info in the installation section for anyone using Ubuntu.
tlp can’t control the charge thresholds, even with the 3.06 bios
root@fw:~# tlp-stat -b
--- TLP 1.4.0 --------------------------------------------
+++ Battery Care
Plugin: generic
Supported features: none available
+++ Battery Status: BAT1
/sys/class/power_supply/BAT1/manufacturer = NVT
/sys/class/power_supply/BAT1/model_name = Framewo
/sys/class/power_supply/BAT1/cycle_count = (not supported)
/sys/class/power_supply/BAT1/charge_full_design = 3572 [mAh]
/sys/class/power_supply/BAT1/charge_full = 3523 [mAh]
/sys/class/power_supply/BAT1/charge_now = 3523 [mAh]
/sys/class/power_supply/BAT1/current_now = 0 [mA]
/sys/class/power_supply/BAT1/status = Not charging
/sys/class/power_supply/BAT1/charge_control_start_threshold = (not available)
/sys/class/power_supply/BAT1/charge_control_end_threshold = (not available)
Charge = 100.0 [%]
Capacity = 98.6 [%]
root@fw:~#
if you do end up using tlp, there is a gui config app called tlpui thats also quite useful
@Quinn_Dougherty what did you end up going with?
I am also running NixOS and have been running ‘auto-cpufreq’. My battery module always shows that a full charge is going to last around 6h under my regular usage. I haven’t done any further experiments.
I am going to give ‘tlp’ a try and see what my battery module reports.
