[TRACKING] WIFI Network adapter disappearing (when physically moving laptop?)
As you’re using AX210, run the following after the next drop. Let’s see what we can gather for the following:
sudo dmesg | grep -i 'auth'
and
sudo dmesg | grep -i 'iwlwifi'
and
sudo dmesg | grep -i 'networkmanager'
Copy and paste the results of each using the </> code editor tool.
stu@fw:~$ sudo dmesg | grep -i 'auth'
[    0.000000]   AMD AuthenticAMD
[    1.925389] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[    2.718185] i915 0000:00:02.0: [drm] HuC authenticated
[   24.324241] wlp166s0: authenticate with 9c:53:22:01:df:d2
[   24.338486] wlp166s0: send auth to 9c:53:22:01:df:d2 (try 1/3)
[   24.406806] wlp166s0: authenticated
[ 1228.369262] audit: type=1107 audit(1711301958.319:102): pid=1272 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.8" pid=9251 label="snap.snap-store.snap-store" peer_pid=1283 peer_label="unconfined"
[ 1228.369521] audit: type=1107 audit(1711301958.319:103): pid=1272 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.PolicyKit1.Authority" member="CheckAuthorization" mask="send" name=":1.8" pid=9251 label="snap.snap-store.snap-store" peer_pid=1283 peer_label="unconfined"
[ 1228.371830] audit: type=1107 audit(1711301958.323:104): pid=1272 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.DBus.Properties" member="GetAll" mask="send" name=":1.8" pid=9251 label="snap.snap-store.snap-store" peer_pid=1283 peer_label="unconfined"
[ 1228.372133] audit: type=1107 audit(1711301958.323:105): pid=1272 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_method_call"  bus="system" path="/org/freedesktop/PolicyKit1/Authority" interface="org.freedesktop.PolicyKit1.Authority" member="CheckAuthorization" mask="send" name=":1.8" pid=9251 label="snap.snap-store.snap-store" peer_pid=1283 peer_label="unconfined"
[ 3498.839211] iwlwifi 0000:a6:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
stu@fw:~$ sudo dmesg | grep -i 'iwlwifi'
[   20.498680] iwlwifi 0000:a6:00.0: enabling device (0000 -> 0002)
[   20.509010] iwlwifi 0000:a6:00.0: api flags index 2 larger than supported by driver
[   20.509040] iwlwifi 0000:a6:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[   20.509774] iwlwifi 0000:a6:00.0: loaded firmware version 72.a764baac.0 ty-a0-gf-a0-72.ucode op_mode iwlmvm
[   20.639507] iwlwifi 0000:a6:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[   20.795099] iwlwifi 0000:a6:00.0: loaded PNVM version e28bb9d7
[   20.806882] iwlwifi 0000:a6:00.0: Detected RF GF, rfid=0x10d000
[   20.882103] iwlwifi 0000:a6:00.0: base HW address: [REDACTED]
[   20.934688] iwlwifi 0000:a6:00.0 wlp166s0: renamed from wlan0
[ 3498.838201] iwlwifi 0000:a6:00.0: Microcode SW error detected. Restarting 0x0.
[ 3498.838532] iwlwifi 0000:a6:00.0: Start IWL Error Log Dump:
[ 3498.838536] iwlwifi 0000:a6:00.0: Transport status: 0x0000004A, valid: 6
[ 3498.838540] iwlwifi 0000:a6:00.0: Loaded firmware version: 72.a764baac.0 ty-a0-gf-a0-72.ucode
[ 3498.838544] iwlwifi 0000:a6:00.0: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[ 3498.838548] iwlwifi 0000:a6:00.0: 0x00008210 | trm_hw_status0
[ 3498.838551] iwlwifi 0000:a6:00.0: 0x00000000 | trm_hw_status1
[ 3498.838554] iwlwifi 0000:a6:00.0: 0x004DB5D2 | branchlink2
[ 3498.838556] iwlwifi 0000:a6:00.0: 0x004D180A | interruptlink1
[ 3498.838559] iwlwifi 0000:a6:00.0: 0x004D180A | interruptlink2
[ 3498.838561] iwlwifi 0000:a6:00.0: 0x0000C2F0 | data1
[ 3498.838563] iwlwifi 0000:a6:00.0: 0x00000010 | data2
[ 3498.838566] iwlwifi 0000:a6:00.0: 0x00000000 | data3
[ 3498.838568] iwlwifi 0000:a6:00.0: 0x22000076 | beacon time
[ 3498.838571] iwlwifi 0000:a6:00.0: 0xC696BF88 | tsf low
[ 3498.838573] iwlwifi 0000:a6:00.0: 0x000001F9 | tsf hi
[ 3498.838576] iwlwifi 0000:a6:00.0: 0x00000000 | time gp1
[ 3498.838578] iwlwifi 0000:a6:00.0: 0xCF4AFB7C | time gp2
[ 3498.838581] iwlwifi 0000:a6:00.0: 0x00000001 | uCode revision type
[ 3498.838583] iwlwifi 0000:a6:00.0: 0x00000048 | uCode version major
[ 3498.838586] iwlwifi 0000:a6:00.0: 0xA764BAAC | uCode version minor
[ 3498.838588] iwlwifi 0000:a6:00.0: 0x00000420 | hw version
[ 3498.838591] iwlwifi 0000:a6:00.0: 0x00489002 | board version
[ 3498.838593] iwlwifi 0000:a6:00.0: 0x8016F400 | hcmd
[ 3498.838596] iwlwifi 0000:a6:00.0: 0x24020000 | isr0
[ 3498.838598] iwlwifi 0000:a6:00.0: 0x01400000 | isr1
[ 3498.838600] iwlwifi 0000:a6:00.0: 0x48F00002 | isr2
[ 3498.838603] iwlwifi 0000:a6:00.0: 0x00C3081C | isr3
[ 3498.838605] iwlwifi 0000:a6:00.0: 0x00200000 | isr4
[ 3498.838607] iwlwifi 0000:a6:00.0: 0x057E001C | last cmd Id
[ 3498.838610] iwlwifi 0000:a6:00.0: 0x0000C2F0 | wait_event
[ 3498.838612] iwlwifi 0000:a6:00.0: 0x00000094 | l2p_control
[ 3498.838615] iwlwifi 0000:a6:00.0: 0x00010034 | l2p_duration
[ 3498.838618] iwlwifi 0000:a6:00.0: 0x0000000F | l2p_mhvalid
[ 3498.838620] iwlwifi 0000:a6:00.0: 0x00000000 | l2p_addr_match
[ 3498.838622] iwlwifi 0000:a6:00.0: 0x00000009 | lmpm_pmg_sel
[ 3498.838625] iwlwifi 0000:a6:00.0: 0x00000000 | timestamp
[ 3498.838627] iwlwifi 0000:a6:00.0: 0x000020EC | flow_handler
[ 3498.838855] iwlwifi 0000:a6:00.0: Start IWL Error Log Dump:
[ 3498.838857] iwlwifi 0000:a6:00.0: Transport status: 0x0000004A, valid: 7
[ 3498.838860] iwlwifi 0000:a6:00.0: 0x20000315 | ADVANCED_SYSASSERT
[ 3498.838863] iwlwifi 0000:a6:00.0: 0x00000000 | umac branchlink1
[ 3498.838865] iwlwifi 0000:a6:00.0: 0x8045F1D0 | umac branchlink2
[ 3498.838868] iwlwifi 0000:a6:00.0: 0x8047EADA | umac interruptlink1
[ 3498.838870] iwlwifi 0000:a6:00.0: 0x00000000 | umac interruptlink2
[ 3498.838873] iwlwifi 0000:a6:00.0: 0x00000004 | umac data1
[ 3498.838875] iwlwifi 0000:a6:00.0: 0x00000200 | umac data2
[ 3498.838877] iwlwifi 0000:a6:00.0: 0x00849604 | umac data3
[ 3498.838880] iwlwifi 0000:a6:00.0: 0x00000048 | umac major
[ 3498.838882] iwlwifi 0000:a6:00.0: 0xA764BAAC | umac minor
[ 3498.838884] iwlwifi 0000:a6:00.0: 0xCF4AFB75 | frame pointer
[ 3498.838887] iwlwifi 0000:a6:00.0: 0xC0887F00 | stack pointer
[ 3498.838889] iwlwifi 0000:a6:00.0: 0x006A019C | last host cmd
[ 3498.838891] iwlwifi 0000:a6:00.0: 0x00100020 | isr status reg
[ 3498.839091] iwlwifi 0000:a6:00.0: IML/ROM dump:
[ 3498.839093] iwlwifi 0000:a6:00.0: 0x00000B03 | IML/ROM error/state
[ 3498.839154] iwlwifi 0000:a6:00.0: 0x000076F9 | IML/ROM data1
[ 3498.839264] iwlwifi 0000:a6:00.0: Fseq Registers:
[ 3498.839315] iwlwifi 0000:a6:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 3498.839367] iwlwifi 0000:a6:00.0: 0x80440005 | FSEQ_TOP_INIT_VERSION
[ 3498.839420] iwlwifi 0000:a6:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 3498.839473] iwlwifi 0000:a6:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 3498.839526] iwlwifi 0000:a6:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 3498.839579] iwlwifi 0000:a6:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 3498.839632] iwlwifi 0000:a6:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 3498.839693] iwlwifi 0000:a6:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 3498.839842] iwlwifi 0000:a6:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 3498.841049] iwlwifi 0000:a6:00.0: 0xA5A5A5A1 | CNVR_AUX_MISC_CHIP
[ 3498.842454] iwlwifi 0000:a6:00.0: 0x0BADCAFE | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 3498.843512] iwlwifi 0000:a6:00.0: 0xA5A5A5A1 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 3498.844522] iwlwifi 0000:a6:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 3498.844551] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3498.869259] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3499.372614] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3499.876633] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3500.380533] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3500.884976] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3501.388915] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3501.892912] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3502.397160] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3502.900533] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3503.404867] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3503.908424] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3504.412600] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3504.917210] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3505.421157] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3505.924519] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3506.428908] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3506.933250] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3507.436727] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3507.566897] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3507.588768] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3508.092573] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3508.596687] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3509.100815] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3509.604949] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3510.108771] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3510.612629] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3511.116482] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3511.620333] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3512.125105] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3512.628830] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3513.132600] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3513.636367] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3514.141127] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3514.644874] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3515.148826] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3515.652642] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3516.156699] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3516.260026] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3516.340249] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3516.844186] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3517.349034] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3517.852816] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3518.356495] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3518.860090] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3519.364198] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3519.868094] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3520.372825] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3520.876539] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3521.380235] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3521.884999] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3522.388759] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3522.892314] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3523.396449] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3523.900436] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3524.404159] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3524.908765] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3525.412658] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3525.916667] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3526.420400] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3526.924167] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3527.427972] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3527.932788] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3528.436554] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3528.940116] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3529.444825] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3529.948663] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3530.452288] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3530.956214] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3531.460246] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3531.964167] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3532.468188] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3532.971872] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3533.475837] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3533.980513] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3534.483996] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3534.988538] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3535.492095] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3535.996646] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3536.499931] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3537.004545] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3537.508192] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3538.011664] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3538.516278] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3539.019865] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3539.524427] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3540.028363] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3540.532138] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3541.036632] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3541.540070] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3542.044296] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3542.548555] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3543.051928] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3543.556226] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3544.059883] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3544.564086] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3545.067791] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3545.572549] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3546.076360] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3546.579905] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3547.084483] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3547.588178] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3548.091991] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3548.595735] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3549.099755] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3549.604424] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3550.107910] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3550.611996] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3551.116429] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3551.619795] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3552.123393] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3552.628119] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3553.131651] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3553.635771] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3554.140119] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3554.643638] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3555.147596] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3555.651853] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3556.156135] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3556.659670] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3557.164247] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3557.667804] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3558.171314] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3558.676253] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3559.179757] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3559.683280] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3560.188009] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3560.691626] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3561.195247] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3561.699940] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3562.203553] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3562.708176] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3563.211698] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3563.715330] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3564.220106] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3564.723708] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3565.227262] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3565.731913] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3566.235615] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3566.739514] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3567.243074] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3567.747602] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3568.251136] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3568.755710] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3569.259624] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3569.763207] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3570.267883] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3570.771373] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3571.275957] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3571.779331] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3572.283898] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3572.787855] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3573.291398] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3573.795036] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3574.299843] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3574.803296] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3575.307860] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3575.811326] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3576.315177] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3576.819807] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3577.218024] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3577.723634] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3578.227280] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3578.731828] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3579.235321] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3579.738928] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3580.243556] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3580.747113] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3581.251644] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3581.755207] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3582.259715] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3582.763293] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3583.267114] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3583.770960] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3584.275532] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3584.779058] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3585.283619] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3585.787585] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3586.291133] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3586.795603] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3587.299083] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3587.803568] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3588.307077] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3588.811564] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3589.314983] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3589.818973] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3590.323585] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3590.827124] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3591.330657] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3591.835300] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3592.338794] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3592.843302] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3593.346833] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3593.851411] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3594.354884] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3594.858572] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3595.363164] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3595.866759] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3596.371286] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
[ 3596.874799] iwlwifi 0000:a6:00.0: Hardware error detected. Restarting.
stu@fw:~$ sudo dmesg | grep -i 'networkmanager'
stu@fw:~$
I recently reflashed Ubuntu 22.04 onto my F13 AMD Batch 8 machine and started having this same issue, whereas this did not happen before for 3 months (when also running Ubuntu 22.04).
rfkill shows wlan unblocked for both soft & hard.
Going to hand this off to @Loell_Framework - if Loell cannot repro, he will instruction you on the next steps.
copy, will try to repro this one :slight_smile:
Hi @Hrafn_Thorvaldsson , this doesn’t to be reproduceable on my end.
can we check whenever it disappears, let’s see the output
dmesg | grep “ZLP”
Hi @Loell_Framework I’ve been waiting for the behaviour to occur again, but apart from the couple of days when it manifested ~18 days ago I have not had it happen again.
Thanks for the update @Hrafn_Thorvaldsson , do let us know if wifi issue resurfaces.
cheers. :slight_smile:
Hey everyone. It’s me again. I’m still using the same 12th generation Intel Framework 13 laptop. I recently purchased a new AX211 wifi card from the Framework online store to see if giving the laptop a new wifi card might resolve my issues. Unfortunately, I again still experienced wifi dropout where it seems like the wifi adapter is suddenly no longer recognized after physically picking up the laptop and moving it.
Any further advice from Framework support would be appreciated. I’ve been battling this type of problem for years now and it’s frustrating.
Current specs:
Intel 12th generation i7-1280P
32GB RAM
AX211 wifi card (non vpro)
Ubuntu 24.04.3 LTS
Firmware/BIOS version 03.19
Ubuntu 24.04 is an officially supported Linux flavor for this laptop model. Ubuntu 24.04 LTS Installation on the Framework Laptop 13 - Framework Guides
Hi Stuart,
If you can please open a support ticket, my team can take a look.
In the ticket, where you indicated it seems to drop off. Please make sure in the ticket to explain if you are seeing the wireless disappear entirely or if it just fails to render websites, ping, etc.
As soon as it drops off - must in the state where it is failing to run this (have this ready in a text file so no connection is needed), run:
echo "--- 1. KERNEL MODULE STATUS (lsmod | grep iwlwifi) ---" > labeled_output.txt && lsmod | grep iwlwifi >> labeled_output.txt && echo -e "\n--- 2. RF-KILL STATUS (rfkill) ---" >> labeled_output.txt && rfkill >> labeled_output.txt && echo -e "\n--- 3. DETAILED HARDWARE INFO (sudo lshw -C network) ---" >> labeled_output.txt && sudo lshw -C network >> labeled_output.txt
Which produces labeled_output.txt to be sent with the ticket with the logs when they request them.
Thank you! I’ll open up this page on my phone so it’s ready next time the wifi drops out.
And file that support ticket with the capture above. What I recommend is having this in a text file, on your laptop. Easier. :slight_smile:
Then reboot, file the ticket, when it occurs next.
It happened! Filing a ticket now.
I have been chasing an intermittent issue with my Intel AX210 for the past 6+ months. but it was very rare until recently. I am on W11 not Linux.
when I close the laptop and reopen it later that day or the next day, the wifi is not recognized, but the bluetooth still works.
I’ve been able to get the laptop to recognize wifi again usually by reinstalling drivers from framework or intel. but nothing is working this latest time around, and the issues has now happened in back to back weeks.
I thought this would be a decent thread to bring this up in, because moving the laptop would generally mean closing and opening it.
W11, AX210 no v pro wifi card, AMD 7840U mainboard.
I am happy to report that on my intel 12thgen laptop, switching to an intel be200 wifi 7 card and/or running Fedora 44 solved that issue (it’s been a month now)
