Trackpad right-click issues (Windows 10)
So I’m not sure if this is an issue with the framework drivers or windows 10 precision drivers but I started noticing that using two fingers to right click was inconsistent. I finally realized that two finger right click would only work if both fingers were a new press on the trackpad. I had gotten used to using one finger to navigate and while keeping that finger on the trackpad I would use my second finger to click. My question is would this be a feature that was unique to my old laptop or am I missing a driver/update. It’s not a big deal if it’s not available it would just take some time getting used to it. Thanks in advanced for any input you all might have.
All I can say is my current asus laptop requires the same new-double-finger-press to right click as your framework laptop
Existing discussion:
tldr is that this is common across all Windows precision trackpads.
