Transparent Orange Expansion Card 3D Print
Anyone know of a Transparent Orange PETG filament that comes the closed to the Transparent Orange Bezel and USB C Cards that frame.work offers?
I want to print a matching ethernet expansion card cover that will match. Came out amazing in Transparent Green, but now switched to orange, and I wanted to matched it
This is the cover for the Ethernet Expansion Card:
If someone from Framework knows any specifics about the color used, you might be able to find a plastic that’s close using this 3D printer filament database: Color Match
Thanks for this! Now I just need the color code :slight_smile:
@Framework Any chance you would know what color code is used for the Transparent Orange?
There was a post from Nirav in a thread where he gave a code for the colour, but it was a while ago and I can’t find it in my history, sorry.
There isn’t really a pantone or hex code that we could define that would appropriately capture the color behavior of a translucent injection molded part. We are testing out filaments manually though to see which ones visually look similar enough.
Hey fellow frameworker, a while ago I asked about the 16 laptop orange frame color and this is the discussion about it, just for reference. What is the color code for the 16' laptop screen bezel?
Awesome! Thank you!
