Any plans to release Ethernet expansion card in the same color as the other expansion cards - silver - and not in a retro transparent case?
I’m also happy to 3D print a case and just move the expansion card internals into it… not sure if there’s a spec posted anywhere.
amoun
#2
Spray it the colour you want.
Thanks! I’ll have to ping my more crafty friends for advice in this area.
Will share if I have a glorious success (or not).
Paint for Plastic models?
oxplot
#6
I’ve used “Krylon Fusion for Plastic” for a long time now with great results.
