I am using Ubuntu 22.04 on latest Framework laptop. I wanted to know if following is a matter of concern as following was generated in about 2 minutes, while charging my laptop:
Is this normal? Can someone tell me what does this means?
$ sudo udevadm monitor
Place your right index finger on the fingerprint reader
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[23192.156202] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23192.195167] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23193.178076] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23193.222781] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23193.436292] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23193.477896] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23194.458124] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23194.507876] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23225.277347] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23225.320830] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23226.300861] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23226.335155] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23232.126416] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23232.165731] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23233.145555] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23233.185590] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23236.923869] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23236.971878] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23237.945080] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23237.978066] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23239.548826] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23239.592555] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23240.569604] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23240.611566] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23246.939852] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23246.979807] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23247.961579] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23247.998016] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23248.187620] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23248.228704] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23249.209432] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23249.251016] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23269.468127] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23269.504479] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23270.044543] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23270.089317] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23270.489094] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23270.521478] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23271.065139] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23271.105173] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23295.772200] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23295.811562] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23296.540724] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23296.580035] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23296.792497] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23296.826770] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23297.562042] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23297.600349] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23300.896235] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23300.950152] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23301.912654] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23301.954184] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23302.653059] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23302.695242] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23303.672660] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23303.711185] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23303.900060] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23303.938272] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23304.573008] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23304.618173] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23304.922565] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23304.967314] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23305.593045] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23305.634470] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23305.755242] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23305.795226] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23306.778244] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23306.817375] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23307.033645] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23307.064969] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23308.056980] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23308.097895] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23309.084095] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23309.126452] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23310.105443] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23310.149749] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23310.334932] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23310.375200] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23311.357321] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23311.403760] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23313.531916] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23313.578251] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23314.553797] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23314.594311] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23314.684881] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23314.720968] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23315.705723] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23315.747209] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23323.738824] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23323.778680] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23324.760689] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23324.795707] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23325.024859] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23325.068046] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
KERNEL[23326.044773] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
UDEV [23326.077516] change /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:1e/PNP0C0A:00/power_supply/BAT1 (power_supply)
