I have to tell someone on the internet about this and since I’m not making another account for Ubiquiti, I’m gonna tell you.
It all started one day in early 2026 when I noticed my network speeds weren’t great. I started poking around and noticed my wifi access point, a UniFi AP AC Pro, had really old firmware. It was running 3.4.7.something, and the current version was 6.7.5.something. Well, let’s just fix that real quick…
Chapter 1. I pressed the “upgrade” button in the app. Nothing happened. I pressed it again. Nothing happened. I pressed it again and again and again. Nothing happened. OK…
After looking around the internet, I found mention that there is a break in the upgrade path somewhere in the 3.x’s, and anything before that requires manual upgrading. OK, so let’s try that.
Chapter 2. Alright, so manually upgrading involves ssh-ing in and either running a command, or copying the file directly. Alright, let’s get in.
Or not.
unable to negotiate, no matching key exchange found
What? OK, what the heck does that mean. OK, fine, how about
-oKexAlgorithms=+diffie-hellman-group14-sha1
no matching host key found
OK, have it your way.
-oHostKeyAlgorithms+=ssh-rsa
Ugh. Not enough.
-oPubKeyAcceptedTypes=+ssh-rsa -oPubKeyAcceptedAlgorithms=+ssh-rsa
invalid key length
COME ON!
-oRequiredRSASize=768
FIIIIINALLY. JEEZ. It took all this to finally connect, apparently due to such outdated security protocols:
ssh -oKexAlgorithms=+diffie-hellman-group14-sha1 -oHostKeyAlgorithms=+ssh-rsa -oPubKeyAcceptedKeyTypes=+ssh-rsa -oPubkeyAcceptedAlgorithms=+ssh-rsa -oMACs=+hmac-sha1 -oRequiredRSASize=768 ui@wifi
Now, please upgrade.
upgrade <URL, I forgot which one I used>
Can’t negotiate SSL with the download server. W.T.F.
Chapter 3. OK, we’ll download it and copy it manually. I pick a version not too far ahead and download it. Now let’s get it over there, using the same ssh options that connected us in the first place. That should work, right?
scp -oKexAlgorithms=+diffie-hellman-group14-sha1 -oHostKeyAlgorithms=+ssh-rsa -oPubKeyAcceptedKeyTypes=+ssh-rsa -oPubkeyAcceptedAlgorithms=+ssh-rsa -oMACs=+hmac-sha1 -oRequiredRSASize=768 /home/user/Downloads/BZ.qca956x.v4.3.28.11361.210128.2309.bin ui@wifi:/tmp/fwupdate.bin
Of course not.
usr/libexec/sftp-server: not found
FFS… OK, what if we ssh in, then scp from that side? NO. Error in libcrypto. OMG. How is this so broken?! Search, search, search, OK what’s this? -O?
scp -O -oKexAlgorithms=+diffie-hellman-group14-sha1 -oHostKeyAlgorithms=+ssh-rsa -oPubKeyAcceptedKeyTypes=+ssh-rsa -oPubkeyAcceptedAlgorithms=+ssh-rsa -oMACs=+hmac-sha1 -oRequiredRSASize=768 /home/user/Downloads/BZ.qca956x.v4.3.28.11361.210128.2309.bin ui@wifi:/tmp/fwupdate.bin
WOW! FINALLY! Copied the file, ssh’ed back in and ran the upgrade command, and finally it did something. After a restart, I tapped the upgrade button in the phone app, and it disconnected again and came back with the current version 6.7.5.something.
But holy frikkin’ cow! I’ve never had to learn so much about manually configuring commands I’ve used so effortlessly before. Computing is a wild world…
Edit: Hidden for being off-topic? In the General section?
